Fuel Gauge going dead?
Old Aug 18, 2005 | 09:06 AM
scottydawg's Avatar
Every once in a while the fuel gauge will go red, drop to E and display an error message in the digital display that says DTE *** Error or something... Eventually it goes away but it's pretty annoying.
Is there a quick fix for this or does it need to go to service?
Also anyone else having a problem with the door handles sticking out a little bit all the time (like a loose retract spring or somethign)?
TIA
Old Aug 18, 2005 | 09:34 AM
Indystang's Avatar
Have you checked to see that all your fuses are pushed in all the way? This was reported early in the production run cars here onTMS forums. Pop the top of the box off and gently push each one with your fingers. Mine were not all the way in when I got mine. It might cause intermittant problems like that. Good luck
Old Jan 11, 2007 | 09:22 AM
albireo's Avatar
I've had my 06 GT in for service at least 5 times for this! Since I can't get it to repeat for them on command, they haven't a clue. The computer doesn't spit a code when it happens... Drives me crazy!
Joe
Old Jan 11, 2007 | 09:27 AM
RubberEater's Avatar
I too have noticed on my '06 that when I take hard right turns, the fuel reading goes alittle of, but nothing to that effect. Usually when I refill the next tank, the gauge reads correctly.
Old Jan 11, 2007 | 10:47 AM
theedge67's Avatar
Check this, see if it matches your problem.
http://bradbarnett.net/mustangs/gala...sb06_10_13.pdf
Old Jan 11, 2007 | 03:44 PM
05BlackGT's Avatar
Well my issue was a little different as my gauge would always read full, but I took my car to the dealer with tsb 6-10-13 and they replaced my fuel pump and sender units. So far that seemed to fix the fuel gauge.
Old Jan 16, 2007 | 07:33 PM
elvism's Avatar
today i had the same problem. same error as posted
here. still my gauge is saying i have more gas miles until empty then really is. my car is tuned so is it safe to take back to the dealer to fix this problem w/ fuel gauge? will they notice my car has been tuned and maybe they will say its possibly because of this ?
Old Jan 16, 2007 | 08:16 PM
05SatinGT's Avatar
I had this exact problem. In my case it was Sulphur contamination. My dealer instructed to try a bottle of Chevron 'Techron' Fuel additive .. If that didn't help thy would perform the repair. To my surprise after 1 bottle
of this additive (Picked it up at Pep Boys) the fuel gauge was back to normal.
Old Jan 16, 2007 | 11:06 PM
05BlackGT's Avatar
It really depends on the dealership, but I just printed out the tsb and took my car in as is. They ordered the parts and asked me to bring it back as close to empty as I could. Yhe repair was done per the tsb, no questions asked. If you're worried, it only takes 10 mins to swap your stock intake and tune and then take it in.
Old Jan 16, 2007 | 11:08 PM
05BlackGT's Avatar
I wish that would have worked for me, but I gave up after five bottles.
Old Jan 17, 2007 | 05:43 AM
elvism's Avatar
john will this affect the tune in anyway by
added this additive. meaning that my car is running on a 93 octane tune. thanks, mike
Old Jan 17, 2007 | 10:28 AM
frdtch05gt's Avatar
I had the same problem with my '05, intermittent issue. Dealer replaced my fuel sender at the same time the gas tank was done, haven't had any problems since.
Old Jan 17, 2007 | 10:42 AM
MaverickMLFD371's Avatar
anyone know if that fuel additive is safe with a JLT intake and 93 octane tune?
Old Jan 17, 2007 | 10:58 AM
elvism's Avatar
i had my tank replace about 5 months ago but
now im having problem
Old Jan 17, 2007 | 03:11 PM
f1-cobra's Avatar
Joe
Try removing the FRD04 AUX Adaptor and see if the problem doesn't go away. That's what was causing my error message.
Old Jan 17, 2007 | 08:53 PM
elvism's Avatar
john, thanks for advice. i bought the additive
. so far so go. ill let u guys know if problem comes back.
Old Jan 17, 2007 | 10:13 PM
RRRoamer's Avatar
I had the same problem with my 05 at the 16k mark. The service manager gave a bottle of the Chevron Techron additive and suggested that I fill up with Chevron gas at least every other fill up. If that did not do the trick, then he would order a new fuel sender board and replace it.
Sure enough, after about 2 months, the problem was totally gone and has not come back. I do make a point to fill up with Chevron gas at least once per month to make sure the sulfar does not have a chance to build back up and start causing problem.
Old May 2, 2008 | 11:19 AM
KevinS's Avatar
I had the same problem using the FRD04-AUX. I went through all the crap of having the battery die, getting the replacement chip, and it worked fine for a few months. Then I started getting the fuel gauge error every couple of days. I removed the adapter and I haven't seen the error since. I tried posting on P.I.E.'s forum asking about it but they deleted my message without replying.
I think this all boils down to the FRD04-AUX being junk, and P.I.E. not knowing what they are doing. I won't be using (or recommending) any of their products for the rest of my life, but I think that's about all I can do about it. It's a shame that people can put out a product like this that so significantly compromises the reliability of a newer vehicle... first it was the dead battery, then the fuel gauge error... these guys have no business doing what they do and it needs to stop.
Old May 23, 2008 | 08:39 AM
8905GT's Avatar
Well this problem just happened to me, fuel gauge is red! I will try to the additive trick but what is the adapter you speak of and where is the fuel sensor located (in gas tank)?
Thx
Old Jun 5, 2008 | 01:24 PM
2005mach1's Avatar
same problem here, started last week. I'll get the addtive and try that first. Im out of warranty so we will see. Fricken empty gas gauge, the code says high circut voltage[ open circut= empty fuel ]
lakersfreak
Jun 13, 2022 12:29 AM
mx5jhb
Sep 30, 2015 04:44 PM
