Front end shudder under braking
Old Feb 8, 2008 | 09:37 AM
Pendarus's Avatar
Hello all!
If I do any hard braking at freeway speeds the front of my GT shutters quite a bit. I am sure it is not the ABS as I get no pulsing in the pedal.
Any ideas? I am assuming the front rotors are warped, but I thought I would see what everybody thinks.
I had the dealership look at it but they could not replicate the problem, and want $115 to do a diagnostic. They did say the rears are "Glazed" and need to be turned. I am thinking about dropping it off at a brake shop and having all 4 rotors turned to see if it helps.
Old Feb 8, 2008 | 09:42 AM
SixtySix's Avatar
Yup, mine do the same thing now. I'm at 50k miles, and more than a few strip runs and canyon carving sessions, so mine are definitely warped, glazed, and you can even see the massive discoloration on my front rotors. They're done!
I've got a pair of drilled and slotted Rotor-Pro's rotors ready to go on though
Save your money, you already know what the problem is!
Old Feb 8, 2008 | 11:37 AM
theedge67's Avatar
You need new rotors. Check out www.newtakeoff.com if you just want the stock replacement parts for cheap.
Old Feb 8, 2008 | 12:42 PM
man your not kidding good price. $40.00 bucks for two rotors
Old Feb 9, 2008 | 12:43 PM
Pendarus's Avatar
Can't I just get the rotors turned? Or are they "toast" now that they have warped?
If I have to replace them I might just spend the money on a set of slotted rotors.
Old Feb 9, 2008 | 12:45 PM
theedge67's Avatar
You could get them turned, yes. The problem is they will be thinner than they were originally. If they warped with the original thickness, they will be easier to warp when thinner. How much is it to have the rotors turned?
Old Feb 9, 2008 | 01:16 PM
SixtySix's Avatar
You can probably get them turned, and they'll be alright for awhile, depending on how hard you are on the brakes.
It could definitely be a stop gap measure before you get new rotors. I got a great deal on mine that I couldn't pass up (slightly used, about 2k miles on them).
You can usually get a set of four turned for around $50.00
Old Feb 9, 2008 | 09:54 PM
theedge67's Avatar
Newtakeoff.com sells brand new stockers for $40 + shipping for the front 2. That is per set, not each. Can't beat that.
Old Feb 11, 2008 | 03:28 AM
Deric's Avatar
I had 2 rotors turned by O'Reily's for $10 a few years ago.
Diode Dynamics
Jun 12, 2018 03:26 PM
RRRoamer
Jan 19, 2017 05:27 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Mackitude
Aug 17, 2015 04:14 PM
