Found base of a Rattle Please READ
Old Jun 22, 2008 | 11:14 AM
jgray5's Avatar
Hey guys....so I've had this terrible rattle that i could not find for the life of me. I thought it was coming from the far right A-pillar. Well the other day i told my sister to drive while i sat in the passenger seat to see if i could mark the rattle in the A-pillar.....low and behold it wasn't even coming from that area. It was not to the left of me. So i i figured it had to be in the middle somewhere. Now i know its not the rattle from the TSB 6-4-1 because Im going to have that fixed when i take car in for the latest recall. TO get to the point....the rattle is coming from the above map lights and head unit above the rear view mirror. That plastic box that has the map lights in it. For some reason it rattles when you go over bumps and if you lightly tap it it makes the sound I've been looking for for months. Now the real dilemma is how to fix it. I notice that when i push on that area towards the roof it stops...MY question is has anyone figured this out before me and has been able to fix it.??
Any help would be great !
Old Jun 22, 2008 | 11:19 AM
jgray5's Avatar
Sorry correction It was not to the RIGHT of me *****
Old Jun 22, 2008 | 11:22 AM
FLAstangx3's Avatar
Velcro.
Old Jun 22, 2008 | 11:28 AM
jgray5's Avatar
thats a good idea...i can try that....have you had this problem ??
Old Jun 23, 2008 | 04:57 AM
Cavero's Avatar
you could also try some double sided foam tape. I used that to fix the door rattle
Old Jun 23, 2008 | 06:25 AM
poldrv's Avatar
I was thinking styrofoam might work.
Old Jun 23, 2008 | 03:25 PM
Cavero's Avatar
Styrofoam would squeak something terrible...
Old Jun 23, 2008 | 03:39 PM
FLAstangx3's Avatar
Yes, but on our 05 Escape. Not the Mustang.
Old Jun 25, 2008 | 05:51 PM
06GT's Avatar
I use the "sticky back" velcro for situations like this. It's available at most craft stores in 18" strips. Usually I only use the felt side, not the hooked side. Use the adhesive backing to stick the felt half to the area of the problem (behind a panel or whatever). The felt portion then fills the gap and prevents rattling of hard metal or plastic pieces. If the gap is big enough, you could use both sides and literally velcro the two pieces together.
The velcro comes in white and black usually.
Old Jul 7, 2008 | 06:59 AM
Jayhawk's Avatar
I bought some double-sided foam tape for a slight rattle under the IUP aluminum end piece (with vent installed) on the far right side of the dash - passenger's side. I lifted the trim piece up and inserted some of the foam tape. Snapped the trim pice back down and so far, no rattle.
Old Aug 3, 2008 | 10:00 AM
jgray5's Avatar
Nice Car Jayhawk !
Old Aug 6, 2008 | 08:22 AM
Jayhawk's Avatar
Thanks! I'm supposed to get her back today from the dealership after repairing the small dent in the bumper fixed. I really, really hope it turns out well. Love that Tungsten!!!
Old Aug 6, 2008 | 08:37 AM
GottaHaveIt's Avatar
I sometimes found that if it's cool out & I'm hummin alone theres the odd small squeek but if I crank up the heater a while to warm the interior that it must expand all the plastics and whalla no more sqeeks. for the small issues anyways.
Old Jan 12, 2012 | 11:29 PM
PJRManagement's Avatar
Currently a Corvette Owner!
Hey, I know this is an old thread, but I have the same **** problem - but with the rear-view mirror. It took me weeks to locate, but I'm now sure it's the rear-view mirror. Has anyone ever had the same issue as me?
Old Jan 13, 2012 | 06:46 PM
houtex's Avatar
Tighten the screw. Either that, or shim the mirror slide mount a little bit. Use a thin piece of plastic, say a water bottle or such, and cut strips until you get it tight.
Unless it's the arm itself, then you could wedge something in the ball/socket, then adjust it to keep it there...
But I'd be gettin' a new RVM if that's the case.
Old Jan 13, 2012 | 06:59 PM
Thanks, houtex. But I cannot locate any screw on the inside windshield mounted rear view mirror. Where would it be? Also, I've done some trouble-shooting, and when I tap the mirror, I hear the rattle. But if I hold the top of the base (where it's mounted to the windshield), and also tap, no rattle. Ideas?
Old Jan 13, 2012 | 11:23 PM
06GT's Avatar
Have the dealer replace your mirror and be done with it.
Old Jan 14, 2012 | 12:44 AM
Yup, going back to the dealer. Thanks for all the help!
Old Jan 16, 2012 | 06:32 AM
FordService's Avatar
Hey PJRManagement,
I’m not sure if you saw my post on your other thread. However, please PM me with your VIN, dealer, mileage, and contact info when you make your appointment so I can help.
Deysha
Old Jan 16, 2012 | 09:24 AM
Thanks, Deysha, I will send you my info when I make my appointment - will be in a week or two.
Peter
