Dash squeek
Old Feb 26, 2006 | 02:11 AM
GTracer's Avatar
OK, I know that lots of other people have had this problem as well but I have to ask...how do I get rid of the squeek on the passenger side of the dashboard? It is in the far righthand corner right under where the windshield meets the dash. I cant take it anymore! [img]style_emoticons/<#EMO_DIR#>/banghead.gif[/img]
Old Feb 26, 2006 | 09:29 AM
SC67Stang's Avatar
Turn up the Stereo!
I have the same squeak and haven't messed with it.
Wish I could find out how to fix this also.
Old Feb 27, 2006 | 11:56 AM
lodom's Avatar
I thought there was a topic about placing foam on top of the dash supports that was getting positive results.
Old Feb 27, 2006 | 02:50 PM
rodneylynn1977's Avatar
<div class='quotetop'>QUOTE(lodom @ February 27, 2006, 12:59 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I took mine in for this problem... They took the dash apart and found a broken post and clip...
now its quiet as can be...
Old Feb 27, 2006 | 04:04 PM
groupset's Avatar
There's a whole 'nother thread on this topic - with detailed instructions on how to fix the rattle/squeak. http://forums.bradbarnett.net/index.php?showtopic=41644
Old Feb 28, 2006 | 04:09 AM
wildhorse's Avatar
Mine is in the far left corner, but not all the time.............It's weird, seems to be more when it is cold outside.
Old Feb 28, 2006 | 11:15 AM
05RedGT's Avatar
My dash squeeks as well - I figured out on mine that it is the A-pillar trim rubbing against the top of the dash - if you push on the A-pillar trim where it meets the dash the squeek stops. Worse when it is cold. I think there needs to be some sort of foam between the pieces.
Old Feb 28, 2006 | 10:42 PM
Original Sin's Avatar
Agree with the last 2 of you guys......the cold definately brings the problem out. Mine is in the same spot as Wildhorse's but it's sometimes there, sometimes not there. Nothing that's gonna drive me nuts 'cause most of the time it's quiet....but a little anoying nonetheless when it "chirps" once in awhile. Maybe a good shot of silicone down there (using the straw of course) would fix it.....and it wouldn't hurt anything that crossed it's path. Might be better than having the dash removed.
Old Mar 1, 2006 | 06:48 PM
Darth Stang's Avatar
Great topic! I had the squeak on the driver's side, and after reading these threads, I put a straight shot of WD-40 down the A-pillar and right at the junction with the dash. That squeak was horrible, and I was actually thinking abiut taking a hammer to it...okay maybe not, but still it was annoying in a new car. Anyway, the WD-40 worked like a dream! No squeaks, so I recommend hitting it as soon as you can and get rid of your headache!
-Darth
[img]style_emoticons/<#EMO_DIR#>/starwars.gif[/img]
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
05PRMTX
Aug 10, 2015 06:38 AM
