Convertible Noises
I have wind noise on my 05 GT Vert between the front and rear window on drivers side and rattles on passenger side
I recently had the rear window on drivers side replaced because it would not close properly
anyone else w issues?
i hope that is not a sign of things to come..all the reviews i read on the vert said how impressed they were over wind,etc. noise from the previous verts....lets just hope yours is a fluke and the dealer can correct i t for you..good luck
Recommend that if you have the top up and your drivers window down, that you have "some" window down on the pax side too. That way the wind will circulate better inside and not "Flap" the back curtain as much while driving, which might lead to premature problems with it.
TC
= Two Cents
TC
= Two Cents
I have rattles occasionally with all the windows up and I have found that if i just press the rear window button and release it as fast as I can, the windows will still be clossed but they won't be pressed against their seals as hard and it really quiets things down, especially over bumpy roads.
There is a really loud rattle in the dash that i'm probably going to see the dealer about.
Rando
Aug 25, 2021 11:12 AM
