charging system problem
Old Sep 18, 2008 | 06:58 AM
cdavila's Avatar
Hey guys yesterday i pilled the positive cable to clean as it had some corrosion on it well today i get to work and the battery light is on and it says to check the charging system i am wondering if i forgot something when i put it back together, i took off the nut at the rear of the terminal {is something supposed to go under the rear nut} and i loosened the smaller nut to the right of the terminal however to retighten it i had to put a screwdriver under it as it was just spinning, any help would be greatly appreciated, after work i will put my sct and check codes.
Old Sep 26, 2008 | 05:22 PM
classix_stang289's Avatar
i see that your post was on 9/18, did you resolve your issure or in need of some help?
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
boz
Oct 1, 2015 04:47 PM
Sep 24, 2015 08:15 PM
