Charging system
Old Jun 29, 2021 | 06:39 AM
sPerez's Avatar
Charging system
06 gt on my 2nd battery and going to replace today 2nd alternator. Read on forums to add a ground wire? Or install a 2010 alternator? If installing ground wire from battery to where do I connect wire to ? And what gauge wire. Any advice is greatly appreciated
Old Jun 29, 2021 | 07:23 AM
Bert's Avatar
If not too late, yes you want the 2010 Denso alternator. They are more expensive but should last a lot longer, hopefully forever. Department of Boost had them for sale a while back, not sure if they still do.
Home | Department of Boost
The battery already has a ground wire, connected to the chassis; otherwise nothing would work . . . I am not sure what the forums were talking about there, maybe upgrading it to heavier cable or making a better connection on the end? For sure you want to make sure that all of the major connections are in good shape (mainly: clean and tight).
Old Jun 29, 2021 | 12:44 PM
RedFire281's Avatar
Legacy Supercharged Tms Member
There are two (2) ground wires from the battery: One to the strut tower at the passenger side and the second to the starter. There is a third ground (ribbon cable) from the rear of the block to the top ledge at the firewall on the driver side.
Along with the power wire from the battery to the alternator, the forums refer to these as the "Big Three" and upgrade to a heavier gauge wire when running a lot of electronics and higher amp alternator. Additional ground wires (Big Five) typically involve the alternator to chassis and heads to chassis. I don't recommend the Big Five unless you're absolutely certain how your electronics are connected as you might cause a ground fault loop and do serious damage. Leave that to the pros.
Old Jun 29, 2021 | 06:39 PM
houtex's Avatar
AAAND... if I my add to this mix of things....
Do this in the link below. I did it to Awesome and that pretty much did away with the issues on battery/alternator. I hope it helps. Good luck! Oh, and a very *very* belated Welcome to the forums, ya lurker ya!
https://themustangsource.com/forums/...4/#post6917899
Old Aug 11, 2023 | 08:58 AM
Jackrwall's Avatar
Hey man I really hope you see this as I need some help with wiring. I have moved the battery to the trunk. The negative terminal on battery is grounded to the body in the rear. I’m assuming G107 is the passenger strut tower ground? And G106 is the ground that goes to the starter? Where on the starter does G106 ground? Since I have moved the battery to the trunk, where can I ground G106/107 now? Is G107 even necessary anymore, as it would just be a ground from strut tower back to body (as it was previously grounded on the negative battery terminal)? Just ground both to the body or frame? Will I have any issues now that the battery is not directly grounded to the engine? Any info you can give me would be greatly appreciated?
Old Aug 11, 2023 | 06:27 PM
05stangkc's Avatar
Welcome!
Although Not Exactly What You Are Asking For this Link and Pdf. Maybe Helpful. The Pdf. Shows an S550 But The Kit is Also Listed For S-197 Applications
Mgb,
KC
File Type: pdf
Old Aug 13, 2023 | 11:47 AM
Jimtrucky's Avatar
2005-2009 alternator issues.
go to American Muscle and order the 230 amp alternator and upgraded bigger gauge positive cable. Problem solved! Did this on my 2006 GT and 2007 GT/CS.
Old Aug 13, 2023 | 11:52 AM
Jimtrucky's Avatar
200 amp alternator. I thumbed the key! Lol
q8despair
1994-2004 V-8
Oct 9, 2020 06:57 AM
Whosit
Mar 3, 2010 10:11 AM
kennyg
Nov 26, 2009 04:05 PM
65steed
May 19, 2006 04:55 PM
rocketcoffin
Apr 5, 2004 02:21 AM
