Blue Smoke on cold starts !! Normal???
Bump...
Mine will do this if say I pull it out of the garage to wash it (cold start-up) and it only runs about 1 minute then sits for 1-2 hours while I wash it or wax it. Then when I start it up afterwards, it gives a slight blue puff. Anybody researched this lately? Mine doesn't puff blue smoke any other time, even when it's very cold outside.
My '05 has done this every once in a while, mostly after sitting in the garage for a few hours for an oil change or something. I haven't seen it happen recently though. My car was driven hard right from day one, and it runs very strong.
Well, got the car back today. They kept it over the weekend to see if it would smoke on Monday morning. They reported that only the normal white smoke.
I told them I would monitor and get back to them if the problem persisted.
Bump...
Same symptoms here
Bump...
I have noticed the blue smoke on cold start up with mine also with under 2k miles. It seems to only do it if the car sets for 4 or 5 days with out driving it. Still kinda strang since I go for up to a month without driving my 89 Mustang and it does not smoke at all.
Just my thoughts........
Steam should not puff out right after it starts. It takes a bit for the cats to heat up. Oil, howoever, will puff right out after a cold start if it is being burned.
^ no it shouldn't but how long do you sit in the car, or gt out and admire it before you get out and notice the smoke/steam, and do your mufflers also drip? if the mufflers are also dripping fairly rapidly within 3-5 mins. its most likly steam which is normal
On my car it is smoke, not steam....it stinks really bad. I'm not worried about it. My car has 36K on the clock with regular oil changes with ford 5w20. It has always done it but has never gotten worse.
I asked my dad about it (he was a mechanic back in college...way back in the day
![Icon Mrgreen](https://themustangsource.com/forums/images/smilies/icon_mrgreen.gif)
My car (and most other's, from what is mentioned on this thread) only does it for a brief second.
As he said: as long as you aren't burning oil while driving, then it's ok...It's not like you have to put a quart of oil in the car between oil changes or anything.
In response to what may be steam: you will definitely see (and smell) the difference between steam and smoke. Burnt oil is thick and bluish and smells like oil. Steam is more white, "thinner", and doesn't smell. Steam out of exhaust pipes will be very similar to steam from boiling water in a pot.
Also, you can usually tell that it's steam, because you will usually see some water dripping from the exhaust tips as well. This is especially seen upon stand-still acceleration.
#40
My 07 GT just blew out a plume of blue smoke yesterday. I had driven it in the morning and moved it out of the garage in the afternoon to wash it. The blue smoke appeared when I started the engine to drive the Stang back into the garage. It lasted for about 15 seconds before steam started coming out. I can definitely tell the difference due to the color, density, smell, and how long it lingers in the air.
I have 4500 miles on the engine (never drag raced or abused) and it is using Pennzoil Platinum 5W-20.
