Battery drain
So, back to the problem and solution -- the simple and cheap solution to the battery drain problem, is to pull the fuse on the radio. Shazam! no more battery drain, and no more radio.
But radios and mustangs are luxuries anyway, we can certainly live without them if we have budget problems.
And you can probably turn up the volume on the i-Phone . . . . hmmmm, or maybe get rid of the i-Phone and use that money to buy a new radio . . . . but I digress . . . .
and yeah I guess I am showing my age too, I remember being able to survive without a fancy CD-changer and with no phone in the car at all.
I don't think you can remove just the CD changer.. IIRC the CD changer and radio are integrated into the head unit.. Either you'll have to pull the fuse when the car is not in use or uninstall the entire head unit and install an aftermarket unit..
Then just put the fuse back in when ready to take your car back out.. Problem solved
Customer satisfaction program would be nice.... In a perfect world, lol. Mine will go about 3-4 weeks until it dies, radio off. Any longer than 2 weeks I usually leave my battery tender plugged in. Works perfect over winter. Come spring she fires right up.
