anybody have leaks from the rear axle
Old Jun 19, 2007 | 07:34 PM
pony power's Avatar
had my pinion gasket replaced 2 days ago on my 06 GT, but they did not fill up the rear with lub so I think I trashed the rear on a car that has less than 8500 miles on it.
Old Jun 20, 2007 | 10:16 PM
Lime GT's Avatar
If they didn't have the rear cover off fluid loss would be minimal. Check your diff fluid level. It should be about 1/4" below the plug hole.
Old Jun 21, 2007 | 07:53 PM
pony power's Avatar
didn't get the chance they are replacing lots of parts in the differentional, that were torn to sheds when I drove it in.
Old Jun 22, 2007 | 06:44 PM
no leaks here except for the brake fluid
Old Jul 5, 2007 | 10:16 PM
281GT's Avatar
Lime GT is correct. The pinion seal is quite high on the housing and there would be very little oil loss. Certainly not enough to damage anything. As suggested just pull the fill plug and make sure the oil is just about up to the hole and you're good to go.
Fords4Ever
Oct 30, 2015 09:07 PM
samjluck
Sep 17, 2015 10:24 PM
Sep 16, 2015 06:44 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 12:44 PM
