Anybody getting a faint knocking sound from engine when cold?
Old Dec 9, 2006 | 08:51 AM
Giddyup's Avatar
I just noticed it this morning, but then it went away when the engine was warmed up. I revved on it a few times after it was fully warmed up, and nothing at all. This all happened when I took the GF to work early this morning, and she said that she could hear it faintly too. It's not the first time I've ever heard it, so I was wondering if this is normal..........if not, then I'm still under warranty for another year yet.
Old Dec 9, 2006 | 09:30 AM
Rash's Avatar
I've had it since day one. Definitely worse when cold.
Old Dec 9, 2006 | 10:39 AM
st06vert's Avatar
I don't think that is normal but I could be wrong. Just wonder why this does not happen to import vehicles.
Old Dec 9, 2006 | 11:02 AM
Northwest GT's Avatar
Just a W-A-guess, but this reminds me of something I had when I installed my CAI. There was a leak in the breather tube to the passenger's side cam cover. What this did was to interfere with the variable cam timing. It needs vacuum to function. At idle it was knocking. Underway, no problem. Fixed the leak and no problems since.
You might want to check for vacuum leaks.
Old Dec 9, 2006 | 12:11 PM
metroplex's Avatar
My TR-3650 has a tapping sound when the clutch is out. When I pull the clutch in, the sound goes away.
Old Dec 9, 2006 | 12:17 PM
stangster's Avatar
Mine does it, so does everyone else's that I've talked to. This isn't the quietest engine in that regard.
Old Dec 9, 2006 | 12:38 PM
metroplex's Avatar
Do you guys have the manual transmission or an automatic?
If it is the manual transmission, I can hear a rattling noise when the clutch is out (engaged with flywheel). The engine itself sounds very smooth and quiet.
If it is the automatic, then I dunno...
Old Dec 9, 2006 | 12:39 PM
tacbear's Avatar
I do in my Patrol Car--2004 Expedition 5.4 L sohc 3V
Old Dec 10, 2006 | 08:14 AM
ov3n's Avatar
Mine also does it.
Old Dec 10, 2006 | 08:41 AM
WB2005GT's Avatar
Mine does it. Sounds like its coming from the pulleys or belt. I just put my stock pulleys back on to see if that makes a difference. It is strange because it goes away completely when the engine warms up.
Old Dec 10, 2006 | 09:00 AM
J2snoop's Avatar
I have noticed this faint 'knocking' sound as well. Honestly though, I'm really not that worried about it. I don't want to take it to the dealer because chances are they'll create more problems just looking for the noise. I don't think it's an issue
Old Dec 10, 2006 | 01:19 PM
metroplex's Avatar
After the engine was fully warmed up, I heard the ticking sound as well. My 4.6 2V V8 does it when fully warmed up, but the 5.4L 2V V8 in the van doesn't make this sound.
As soon as you open the throttle, the sound disappears.
Old Dec 10, 2006 | 01:48 PM
tdbrown75's Avatar
I have stopped listening to mine. Misty ticks, whines, and clicks all the time. I noticed when I installed my CAI, but I never listened that closely before the CAI so when I got worried I returned it to stock and it was the same. This is by far the noisiest car I have ever owned, and that’s part of the charm I suppose. So long as I do not hear anything different or sudden, I’m not going to sweat it!
Tim
Old Dec 10, 2006 | 02:06 PM
SteelTownStang's Avatar
I have a 5sp and nothing as described here
Old Dec 11, 2006 | 06:09 AM
lodom's Avatar
It could be loose clearances in the engine that tighten up when the engine is warm. GM LT1's and LS1's have had a problem with piston slap that usually disappears when the car is warm. Since the engine block and heads are aluminum with over head cams, you'll likely hear more noise than you would on a comparable iron block engine with over head valves. As long as the noises disappear when the car warms up, it is probably normal, unless you have a chain tensioner issue that has been mentioned in the TSB.
Old Dec 11, 2006 | 06:14 AM
05retro's Avatar
i just noticed it this morning in mine. Its a clicking sound and not at all a metallic sound like the transmission inspection plate that many of us can remember. This will need some further inspection.
Old Dec 11, 2006 | 06:33 AM
metroplex's Avatar
I hear the ticking sound only when the engine is fully warmed up. It sounds just like my Romeo 4.6 2V V8. The Windsor 5.4 2V V8 in the E-250 is silent/smooth.
Old Dec 11, 2006 | 07:21 AM
WB2005GT's Avatar
I put my stock pulleys back on and the noise is gone. I will put the Steeda pulleys back on in a few weeks and see if it comes back. The noise I had was really loud and may not be the same one that others were hearing.
Old Dec 11, 2006 | 07:44 AM
metroplex's Avatar
If the Steeda dampener is smaller than the stock diameter dampener (not the ribs where the belt rides), it can allow some vibrations to be undampened, leading to oil pump gear failure (at least on the 2V engines) at high RPMs. Make sure you torque the crank pulley bolt properly (If it is a TTY bolt, follow the procedure). It's easier to torque properly with a manual transmission than with an automatic.
Old Dec 11, 2006 | 09:25 AM
rhumb's Avatar
Knocking noise might well be just a bit of minor piston slap when the motor's cold. As mentioned, the aluminum GM LS motors had similar issues. AL, IIRC, has a bit more thermal expansion than FE, thus, the tolerances are thus a bit looser when cold to accomodate this. Add to this that AL tends to transmit noises a bit more than FE and the generally looser, friction-reducing tolerances on today's motors and voila, a bit of knock on those chilly mornings. Take it a bit easy on the poor gal till she warms up and, presuming the sound fades away on warmup, no real issue.
Ticking noises could either be a slightly sticky HLA (hydraulic valve lifter) or even just the fuel injector actuation noise sneaking past. If a very light sounds, probably no issue. If a bit louder, and suspecting a sticky or clogged lifter, you might try an engine oil flush to clean out any offending grunge. The HLAs can have some pretty tight clearances and internal passages, so it doesn't take too much to gunk them up a bit.
