Alignment question
Alignment question
Issue: My car pulls ever so slightly to the left even after alignment. Given my numbers below, should I go back in for another alignment or should I be looking at something else for the problem? (i.e., should the camber/caster numbers be a little more even between the left and right?)
Alignment history: My car has felt like it's had great alignment from the factory even after 5 years including new tires after 4 (shop verified it didn't need an alignment at the time). Recently it felt like the car started to pull just a little to the left, even when on the right side of a crowned road. i.e., If I let go of the wheel centered in the lane, I'll just touch the center line after about 5-10 seconds or so. So I got it aligned but it still pulls just a hair to the left. What gives?
Here are my alignment numbers:
Front:
Camber: [FrontLeft -0.8] [FrontRight -1.2] (SpecifiedRange -1.5/0.0)
Caster: [FrontLeft 6.9] [FrontRight 7.4] (SpecifiedRange 6.4/7.9)
Toe: [FrontLeft 0.02] [FrontRight 0.06] (SpecifiedRange -0.05/0.15)
SAI: [FrontLeft 8.5] [FrontRight 13.0]
IncludedAngle: [FrontLeft 7.7] [FrontRight 11.8]
CrossCamber: 0.3 (SpecifiedRange -0.8/0.8)
CrossCaster: -0.5 (SpecifiedRange -0.8/0.8)
CrossSAI: -4.5
TotalToe: 0.08 (SpecifiedRange -0.10/0.30)
Rear:
Camber: [ReartLeft 0.1] [RearRight -0.2]
Toe: [RearLeft 0.07] [RearRight -0.17]
CrossCamber: 0.3
TotalToe: -0.11
ThrustAngle: 0.12
Front:
CrossSAI: -4.5
Rear:
CrossCamber: 0.3
TotalToe: -0.11
ThrustAngle: 0.12
I read that the left Caster should be more negative that the right but no more than half a degree to account for road crown to the right. Similarly, left camber should be more positive than the right for the same reason. My numbers meet this critiera but even on crowned roads I still pull left just a little. There's only one crowned road near me that's heavily crowned where the car tracks straight. I'm wondering if I just get the guys to even up those numbers a little if that will solve my problem.
I'm also wondering if I'm just being ridiculously **** and should just let it go
