I'll test it tomorrow, the car is actually running now. But a lot of smoke and gas smell codes popped up for too rich now. O2 sensors. I didn't drive around bit I wasn't sure if the too rich was from me trying so much and maybe flooding the engine. I have no idea why it just suddenly decided to start again as well. So no im just even more confused. I was sort of thinking my fuel filter might be bad just because I've replaced the pump and went back to original and maybe some debris got in there. Not sure if that could be it. I'm still stuck on the fact it's running. But does have a whining noise. Idk if you can hear it in the video but when im inside the car, I hear it, when I go out to check, I can't really tell.
Description: The powertrain control module (PCM) monitors the fuel level input (FLI) communications network message for a concern. The test fails when the FLI signal is less than the minimum allowable calibrated parameter for a specified fuel fill percentage in the fuel tank. Possible Causes:
Empty fuel tank
Fuel pump (FP) module concern
Incorrectly installed fuel gauge
Damaged instrument cluster
Damaged fuel gauge
FLI circuit short to ground
Diagnostic Aids: Monitor the FLI PIDs in key ON, engine running. A concern is present if the FLI percentage PID is at 25% fill and the FLI voltage PID is less than 0.90 volt with a non-matching fuel gauge or the FLI percentage PID is at 75% fill and the FLI voltage PID is greater than 2.45 volts with a non-matching fuel gauge. ApplicationKey On Engine OffKey On Engine RunningContinuous Memory All
GO to Pinpoint Test HX.
P0463 - Fuel Level Sensor A Circuit High
Description: The powertrain control module (PCM) monitors the fuel level input (FLI) communications network message for a concern. The test fails when the FLI signal is greater than the maximum allowable calibrated parameter for a specified fuel fill percentage in the fuel tank. Possible Causes:
FLI circuit open
FLI short to VPWR
Overfilled fuel tank
Damaged fuel gauge
Diagnostic Aids: See the diagnostic aids for DTC P0462. ApplicationKey On Engine OffKey On Engine RunningContinuous Memory All
