05 mustang smoking under the hood
Old Nov 23, 2018 | 12:55 AM
Ados's Avatar
I just bought an 05 mustang v6 with 150k miles on it, it runs good and drives good, but just recently smoke started pouring out of the radiator. I’m 18 and do not know much about cars, please contact me if you’d like to help. I have pictures and videos of where the smoke is coming from
Old Nov 23, 2018 | 05:33 AM
Paris MkVI's Avatar
Is it smoke? Or steam?
Old Nov 24, 2018 | 11:09 AM
Cavero's Avatar
What color is it? Mostly white? Blue-ish? What does it smell like? burning? Or sweet?
Old Nov 26, 2018 | 12:10 AM
Lime GT's Avatar
If smoke is coming from the radiator it may be "steam" which means there is little or no coolant. Check your coolant recovery bottle, there is a cold fill line {read the owners manual}. Also check for leaks around the radiator area. It's also possible your thermostat is stuck closed which will cause the engine to overheat. If it overheats too much it may cause the engine to go into "limp mode" which will inhibit transmission function and reduce engine performance. Running the engine too long without coolant may also cause a head gasket to blow which will be major money to repair.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
TMS Editor
Mar 20, 2016 07:49 PM
rhumb
Jan 22, 2015 08:47 PM
clockworks
Sep 29, 2005 05:39 PM
EleanorsMine
Aug 13, 2004 07:46 AM
