What the heck is this?
Old Dec 7, 2007 | 10:06 PM
KEEP's Avatar
What is this thing with the **** and the brake lines? Better yet, what does it do if I turn the ****?
Old Dec 7, 2007 | 10:08 PM
ShowGT's Avatar
it looks to be a brake proportioning valve
Old Dec 8, 2007 | 07:07 AM
Extreme21's Avatar
it appears next to and/or part of the a/c unit. a makeshift recharger? i say that 'cause it looks like a contraption i used to attach to the lines in a home unit to add freon to the unit.
ummm....brake proportioning valve sounds good too.....whatever that is
Old Dec 8, 2007 | 07:15 AM
Ackman70's Avatar
It's a brake proportioning valve. It's needed when a rear disc conversion is done. It adjusts the brake bias front to rear. Turn the **** one way it puts more front brake in. Turn it the other way and you get more rear brake.
Old Dec 8, 2007 | 07:19 AM
Extreme21's Avatar
Cool! So....most of us would just turn it to the "no brake" setting
Old Dec 8, 2007 | 08:47 AM
Puter's Avatar
And I third this.
Have you got rear discs on that thing?
Old Dec 8, 2007 | 01:15 PM
KEEP's Avatar
Originally Posted by Puter
And I third this.
Yep... and thanks for the comments. I had hoped that is was for a hidden turbo or something.
Old Dec 8, 2007 | 03:23 PM
Mberglo's Avatar
To verify the adjustment, find a safe place to get to speed and slam on the brakes. The fronts should lock up just before the backs lock up. If the backs lock up first, it could send you spinning.
Here's the wierd part: to delay braking to the rear brakes, you turn the proportioning valve counterclockwise.
bob724
Aug 17, 2015 04:05 AM
slufoot733
Aug 2, 2015 07:15 PM
Jay
Sep 28, 2004 08:32 PM
