Resource Question
Old Feb 25, 2007 | 05:36 PM
KEEP's Avatar
Resource Question
Where is the Stang bone-yard these days. There used to be one out in Arab but I spent all day looking for it and never found it. I have hopes of finding a rolling chassis that is worth bringing back to life.
Old Feb 26, 2007 | 08:39 PM
kkucera's Avatar
4 banger cars are always a good value if you just want a chassis.
Old Feb 27, 2007 | 12:18 PM
HOSS429's Avatar
legacy Tms Member
cept for maybe the gullatt boys no-one has a stash of older stuff.. bama parts in hazel green has lots of later wrecks..
Old Feb 27, 2007 | 01:14 PM
Greg G's Avatar
Rebuilder
We (Gullatts) are opposite of a "bone yard". We rescue distressed Mustangs and put them back together. Been a lot of confusion over that over the years. Just about every old Mustang we purchased over the years are/were missing most of the major components or stripped. It has taken a long time to collect the parts to put them back together.
Old Feb 28, 2007 | 05:47 PM
HOSS429's Avatar
legacy Tms Member
help MR wizzard
i dont want a thread on it .. i have built a 351 windsor late model california engine so i hear ... it had the distributor signal at the crankshaft.. i deleted all that and went back to a regular elec ign of late 70`s vintage .. problem is the engine will not perform at all at a normal initial distrubitor timing setting ..set the timing high enuff to run and it wont start.( kicks back like too high ) .. i thought perhaps the timing chain was dif on a later engine so i got an older gear 69- 84 or so ... it fits just the same so it will not change anything.. but it does offer 4 degrees of advance before and after which does change the cam location .. which setting do i need to use to liven up the engine .. it has edlebrock alum heads and a 292 comp cam .. not much more .. stock bottom
Old Mar 2, 2007 | 05:45 AM
HOSS429's Avatar
legacy Tms Member
well i`m gonna put it back together saturday in the plus 4 degrees position and see what that does.. we may all learn something ...
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
