Question about battery
Old Nov 29, 2008 | 11:14 AM
BA Mustang's Avatar
If my battery gets rained on while in the car could this cause it to not have enough power to crank the mustang? Tired to start the mustang this morning and it would barley crank and then after about 5 cranks it just clicked. Now I think it is flooded right now since gas is on the carb spacer.
Old Nov 29, 2008 | 03:03 PM
mustang6804's Avatar
When you say clicked do you mean the battery sparked, or it just started? i believe letting a battery get rained on might have a few effects on it.
Old Nov 29, 2008 | 03:06 PM
BA Mustang's Avatar
Click doesn't mean spark. I would have said sparked if I meant sparked. The starter clicked.
Old Nov 29, 2008 | 04:48 PM
kennyg's Avatar
I bet the starter didn't click, I bet it was the solenoid. kennyg
Old Nov 29, 2008 | 05:13 PM
BA Mustang's Avatar
Ok. We are going to charge it tomorrow and see if it will start.
Old Nov 29, 2008 | 09:12 PM
Rogue's Avatar
cold weather is really hard on a battery, might be getting weak
Old Nov 30, 2008 | 07:43 AM
Puter's Avatar
Rain does nothing to a battery. Charge it and you should be fine.
Old Nov 30, 2008 | 08:42 AM
BA Mustang's Avatar
The battery was replaced in the spring, so I hope it isn't weak already.
Old Nov 30, 2008 | 01:53 PM
If it was the solenoid, thats an easy and cheap fix. Hopefully itll run after it charges
Old Nov 30, 2008 | 02:15 PM
BA Mustang's Avatar
The solenoid isn't broken, it will do that when there isn't enough power.
Old Nov 30, 2008 | 05:13 PM
BA Mustang's Avatar
Well we finally got it started. The battery isn't getting enough power to start the mustang. Charged the battery took off the charger and it wouldn't start. Put charger on and tried and it started.
Old Nov 30, 2008 | 05:50 PM
Rogue's Avatar
it is one of 3 things , bad cell in the battery, bad battery cable-or connection or failing starter(causes drag and needs more power to turn over)
Old Nov 30, 2008 | 06:10 PM
BA Mustang's Avatar
I would think starter. This was all of the sudden. Drove it all this week and then went out yesterday to move it and it wouldn't start. Now I just have to make it last until Christmas break.
Old Nov 30, 2008 | 08:13 PM
Rogue's Avatar
wifes mustang wouldnt start today , completly dead ,
i found out she left the dome lights on for 5 days,
i cant believe the dome light would kill a battery in 5 days but i guess so
Old Nov 30, 2008 | 08:23 PM
BA Mustang's Avatar
I just put in a dome light in mine(about 3 days ago). Took it out now, just in case.
Old Nov 30, 2008 | 11:40 PM
k3druid's Avatar
Check for a Dead Cell, sure sounds like it.
Test with a Voltmeter with car turned Off for 5 Minutes, if you measure below 10 volts
you got a Bad Cell. OR most Battery places will check it for you, Free.
if it's still under Warranty see your Dealer or where you bought The battery.
Old Dec 1, 2008 | 05:33 AM
BA Mustang's Avatar
It reads 13 when sitting and then turned on about 12. Once we got it started it jumped to 14.
Old Dec 1, 2008 | 06:46 AM
do you know how old your starter is? I know that you've got fairly new battery cables.
Old Dec 1, 2008 | 08:54 AM
usmcrebel's Avatar
had this happen to me when i was building mine, and it was my starter, solenoid, and battery....as a matter of fact if you need a solenoid...i have one laying around
Old Dec 1, 2008 | 02:29 PM
BA Mustang's Avatar
Well it started fine in the school parking lot after sitting there for 9 hours.
