Offset?
Old Jun 2, 2008 | 07:36 PM
BA Mustang's Avatar
Offset?
Will a set of rims with -10 offset fit my mustang?
Old Jun 2, 2008 | 08:59 PM
mmr007's Avatar
I'd love to help but I am soooooo the wrong person to ask
Old Jun 2, 2008 | 09:09 PM
BA Mustang's Avatar
I'm about as confused as you are on offset.
Old Jun 3, 2008 | 01:22 PM
BA Mustang's Avatar
Well now the guy says they are +10 offset. So will either of these work?
Old Jun 3, 2008 | 05:52 PM
mgreene's Avatar
Not sure what a +10 or -10 means. Offsets are usually expressed in inches from the center of the wheel.
Old Jun 3, 2008 | 07:56 PM
BA Mustang's Avatar
That is in mm.
Old Jun 3, 2008 | 08:10 PM
mgreene's Avatar
Originally Posted by BA Mustang
That is in mm.
10mm is less than 0.5 inches - not much offset either way...
Old Jun 4, 2008 | 06:35 AM
Puter's Avatar
Offset is only one measurement. What is the diameter and width? And do you know the bolt spacing?
Old Jun 4, 2008 | 07:19 AM
BA Mustang's Avatar
Ok I think these are what you want. They are 14x6 with a 4x114.3 bolt pattern.
This 1 guy some weld draglites on Huntsville Racing, just depends on how much he wants them I might get them instead.
Old Jun 4, 2008 | 08:31 AM
StangRalle's Avatar
Mustang Wheel Offset
The offset of a mustang wheel is the distance from the hub mounting surface to the centerline of the mustang wheel. It is very important to purchase a wheel with the correct offset for your year Mustang. If the offset is not right for your mustang, the steering and handling will be affected.
There are three types of offset:
1. Zero Mustang Offset: This means that the hub mounting surface is even with the centerline of the wheel.
2. Positive Mustang Offset: The hub mounting surface is toward the front (face or wheel side) of the wheel. Positive offset wheels are generally found on front wheel drive cars, as well as on newer rear-wheel drive cars.
3. Negative Mustang Offset: This means that the hub mounting surface is toward the back (or brake side) of the wheel’s centerline.
Mustang Wheel Backspacing:
Backspacing is distance from the back edge of a wheel rim to the back of the center section. Measured in inches, backspacing is closely related to offset. This measurement is important because it determines the clearance of the wheel in the well, and the amount the wheel will stick out.
You can measure a wheel’s backspacing by running a straight edge across the rim bead and dropping another straight edge down to the wheel face, measuring that distance.
Mustang Wheel Bolt Pattern:
The bolt pattern is the diameter of the circle made by the centers of the wheel lugs. So, for our 5-lug wheels, a bolt pattern of 5 x 4.5 inches means that the lug pattern falls on a circle that is 4.5 inches in diameter.
Note: 5x4.5 inches is 5x114.3 mm
Old Jun 4, 2008 | 12:25 PM
BA Mustang's Avatar
Well I am hopefully going to get these Draglites. Just waiting on parents decision and more info about them.
Old Jun 4, 2008 | 12:39 PM
usmcrebel's Avatar
who's are they, i can get info pretty quick from them guys
Old Jun 4, 2008 | 12:50 PM
BA Mustang's Avatar
I am on huntsville racing. I switched my name to Gnatsum. Which is Mustang backwards. The guys username is Horsplay.
Old Jun 4, 2008 | 01:14 PM
usmcrebel's Avatar
ok, if you dont get an answer i'll try to find stuff out...i'll give you 1 guess my name on there
Old Jun 4, 2008 | 01:18 PM
BA Mustang's Avatar
Well those are out of the question now. The front rims were WAY to skinny for my car. They were 15x3 1/2. I have 14x4....
Old Jun 4, 2008 | 01:37 PM
usmcrebel's Avatar
yeah i just saw that.
Old Jun 4, 2008 | 01:51 PM
BA Mustang's Avatar
I want some 14x6 or 15x6 rims. If not my mods will go even higher.
Old Jun 4, 2008 | 09:18 PM
BA Mustang's Avatar
Well I am now looking at conversion adapters. Might convert from 4x4.5 to the fox body 4x4.25 bolt pattern.
Old Jun 5, 2008 | 04:53 PM
BA Mustang's Avatar
Well hopefully soon my mustang is going to look like this. We are in the process of deciding whether or not to get wheel adapters. If we do get them those will be the rims selected for the mustang. I would really like a set in black though.
Old Jun 6, 2008 | 06:20 PM
BA Mustang's Avatar
I have 1 last question. Will these 16" rims fit on my mustang even with the 1" drop?
DarrenGT
Apr 2, 2020 11:52 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
14BlackGT
18
Mar 10, 2017 04:13 PM
