need info any will help
Old Oct 12, 2010 | 03:45 PM
hoofbeat95's Avatar
looking for anyone that has ever put a 351w stroker in a fox body and kept it fuel injected,i would like to know some info on some of the parts....i am putting a 351w 383 in my 1969 mustang and i want to put a fox body wiring in it and make it fuel injected,but will the cpu run this motor? has anyone ever done this?
Old Oct 12, 2010 | 10:23 PM
Rogue's Avatar
http://www.midnightdsigns.com/Mustang/Engine.htm
351 and 302 will be the same
worst case scenario you would need the fuel map modified
Old Oct 13, 2010 | 07:17 AM
Mberglo's Avatar
They aren't quite the same. You'll need to find a 351 intake, probably from an F-150. Get one that uses the Mass Air Sensor and the cpu should be able to compensate. You'll probably need a larger injectors and a larger throttle body and mass air meter to handle the extra cubes.
If you want an exhaustive search and discussion, I suggest you look for info at www.corral.net. Those folks have done all of the fuel injected small block Ford variations there are.
Jul 8, 2016 08:53 AM
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
scott6809
Sep 12, 2015 11:44 PM
09-gt/cs
Aug 14, 2015 08:52 AM
