Wrong Gas in Tuned 5.0
Old 6/6/11, 11:55 PM
Cusp's Avatar
Some one remembered their algebra mixture exercises.
Old 6/7/11, 12:01 AM
really? that's algebra? I thought it was just percentages.
Old 6/7/11, 12:25 AM
Everett's Avatar
Or division.
Old 6/7/11, 10:55 AM
SoSlowGT's Avatar
Old 6/7/11, 04:17 PM
Legacy TMS Member Moderator
HoosierDaddy's Avatar
Originally Posted by SoSlowGT
Your mixture of 3.57 gallons of 87 in a 16 gallon tank with the remaining gas (12.43 gallons) being 93 octane should theoretically put your octane rating at 91.66 octane.
And its probably higher than that because although tetra-ethyl lead is banned, the refineries do add octane boosters to gas. And that does not have a linear effect. The additives in the 91 will raise the octane of what was 87 more than their leaving lowers the octane of what was 91.
Old 6/7/11, 08:21 PM
SoSlowGT's Avatar
If you look on the pump most gas can be "Up to 10% E85 ethanol" which has a higher octane rating than "93 Premium."
So yes, if you factor in that E85 is commonly quoted as being 100-105 octane and up to 10% of your tank could be E85 you may be above your quoted "minimum octane rating."
But as I stated to the OP earlier, I stay on the better safe now than sorry later side.
Old 6/7/11, 08:37 PM
Everett's Avatar
Ethanol may have a higher octane rating but there is less energy in ethanol than gasoline. Regular actually has more than premium. Octane is a rating on the detonation resistance of fuel.
Old 6/7/11, 09:25 PM
Hmmm... E85 is not 10% eth.
In Oregon 'premium' has only been 91 octane on the pump label. Until the dictator governor demanded 10% eth content - then the labels changed to 92. So its 90% 91 gasoline + 10% eth = 92 octane 'premium'.
Old 6/8/11, 09:29 AM
SoSlowGT's Avatar
Yes, but I believe the OP is worried about detonation with low octane fuel, not horsepower.
Old 6/8/11, 09:31 AM
SoSlowGT's Avatar
We have 93 and 100+ octane pumps in parts of GA and AL.
Antigini-GT/CS
10/5/15 09:43 AM
MustangGTCS13
9/17/15 07:38 AM
Grabber5.00
9/13/15 06:53 AM
Cdvision
9/5/15 05:22 PM
Quick Reply: Wrong Gas in Tuned 5.0
