Wiper-washer issues
Old Nov 26, 2023 | 07:28 PM
mgreene410's Avatar
Wiper-washer issues
Hello all, my daughter recently purchased a 2010 convertible V-6, automatic transmission car. Initially the wipers would not work most of the time. After some research we cleaned the cowl drain, which was of coarse plugged with pine straw, and replaced the wiper motor with one from Orielly Auto Parts. Everything seemed to work fine other than the hole on the wiper linkage being stripped out. I fashioned some washers and tightened down the nut so the wipers worked correctly and would return to home as they should. About a week later she called me and had to remove the wiper relay to get the washer to quit spraying water. She brought it home a day or 2 later, we re install the relay and everything is perfect. About 2 weeks later the same thing happens again? I did re check the water box at the wiper motor and it is still completely dry. Anyone had a similar experience or know what I should check when it works fine when she brings it home? Thanks
Old Nov 26, 2023 | 08:19 PM
05stangkc's Avatar
@mgreene410
Yep!
https://themustangsource.com/forums/...issues-550039/
If Wiper Motor was a REMAN Unit Might a Bum Rebuild!
Dtc Codes Are in Here Last PDF.
https://themustangsource.com/forums/...e-info-550475/
KC
inky86
Oct 15, 2023 12:43 PM
Cluarain
Repair & Service Help
Feb 18, 2023 10:12 PM
Keiferh
Jul 23, 2021 08:43 PM
Boomer
Nov 13, 2010 02:03 PM
sprint200
Apr 1, 2007 11:04 AM
