Window Stickers
- May be delayed by the plant shutdown late last week due to the part shortage from Europe.
- Keep looking . Refresh is your friend - it *will* show up.
We have another member with the same issue (and likely others). Their are a lot of cars that were recheduled for 4-26 due to the shutdown due to a parts shortage last week. Check again Monday and Tuesday.
If you know your blend number, mine is 7290. That might help you figure out where you are. They have been averaging a little under 300 cars a day (on a 5 day work week).
http://www.pgroup-inc.com/testing/vin.php
I found 2 different links to use the VIN to get the window sticker. I also was late getting the sticker, because I couldn't get it using the first link, but when I found the 2nd link, it worked fine. The one that worked was:
Supposed to be built tomorrow :/
this link worked fine for me Thank-You !
How can you tell the build day from the 'Blend' number? My V-6 is in 'Transit', my 'Blend' number was 1140. Would that be April 11th? Built on a Sunday?
