Will smaller diameter front tires cause abs/ traction control issues?
Old May 19, 2015 | 12:01 PM
2012White5.0's Avatar
I can't seem to find any concrete information but would a 255/40/19 up front with 275/40/19 in the rear cause issues with abs and or traction control?
I may just stick with a 245/45 up front and just have it alittle stretched
Old May 19, 2015 | 12:09 PM
Horspla's Avatar
No issues. It's common to have larger wheel/tire selection in back verses the front.
John
Old May 19, 2015 | 02:11 PM
5.M0NSTER's Avatar
What John said. You'll be fine with that combination. You could run into issues if you have vastly different front/rear size tires, but with the sizes you mentioned the rolling radius difference is minor.
Old May 19, 2015 | 06:19 PM
SplitSecond's Avatar
You would run into trouble if you were running different size tires on the same axle.
Old May 19, 2015 | 08:34 PM
Trumpetlon's Avatar
I just looked at a 2015 50th anniversary and those were the sizes Ford put on that car. What I found odd was that Ford put a 275 on an 8.5 inch wide wheel....
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Ecostang
Nov 3, 2022 08:50 PM
CoyotePremium13
Aug 18, 2015 07:28 AM
Mackitude
Aug 17, 2015 04:14 PM
