Will changing to a one piece driveshaft (aluminum or CF) throw off pinion angle?
Old Aug 10, 2011 | 03:42 AM
2012GT's Avatar
anyone
Old Aug 10, 2011 | 06:00 AM
BlackOut2k11's Avatar
I never heard of this happening on previous years so I would be surprised if it happened on our cars.
Old Aug 10, 2011 | 08:01 AM
The Sheriff's Avatar
Originally Posted by 2012GT
anyone
Apparently someone thinks so.
https://themustangsource.com/f800/al...497112/index2/
Old Aug 10, 2011 | 08:03 AM
CO_VaporGT_09's Avatar
It's the lowering that throws off the pinion angle. The angle is more critical when you have a one piece shaft, so if it's not ideal you'll get vibrations or worse. Having adjustable upper or lower control arms will allow you to change it to the ideal setting.
There is some variations from the factory, of course, and just the variable weights of the cars (options, etc) will alter the amount of pinion angle change when you lower.
The two piece shaft has those three articulation points to compensate for any minor non-optimal angles.
Read more here:
http://www.steeda.com/store/uploads/...ol-arm-1-1.pdf
http://www.youtube.com/watch?v=i8FNgaNqS8s
Mr. V
Dec 24, 2016 02:57 PM
dblhelx
Oct 6, 2015 08:08 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
50Cal
Sep 17, 2015 06:43 PM
Sep 16, 2015 06:44 PM
