Where can I find the processor code on a 12 5.0?
Look on the front passenger side of the engine bay. You'll see a big fuse box. Just to the driver's side of that, you'll see a wedge-shaped object with a large heat sink on the fuse box side. There are three large plugs going into the front face of it. This is the PCM. If you put your head right at the fuse box, and look at the front fuse-box-side lip of the PCM, you'll see a few stickers. The one towards the bottom of the car will contain a 4-digit code. Mine was PSZ2; yours should be similar.
