Wheel Swap
Old Jun 10, 2014 | 03:47 PM
firstang001's Avatar
Wheel Swap
Hi Guys, I recently bought a 2013 Mustang V6. These came with 17inch wheels stock. I hated them. I immediately found a local deal who was selling the 2014 Ford GT Track pack 19inch wheels. I always wanted to go that route and grabbed them instantly. Got them installed and they look amazing. But I wanted to know if I should be getting my odometer re calibrated? Can I test my speedo/Odo test in anyway?
Thanks......
Old Jun 10, 2014 | 04:04 PM
Ltngdrvr's Avatar
Those new tires are shorter than the stockers so the speedo will read high now.
Unfortunately, there is no recalibration available short of a pcm tune.
Now, if you want a factory tune that will match the tire size for the V6, the Performance Package cars came with the same tires. So, you can get a dealer to reflash the pcm with the Perf Pack tune to correct the speedo.
Only other option is an aftermarket tune, but then you have warranty issues possible.
Old Jun 10, 2014 | 05:22 PM
I thought that the shorter tire size is compensated by the bigger rim(17 inch -->19inch) ? I know it looks stupid but I did a side by side size comparison while shop was installing them they look identical to the naked eye. Do you have an idea how much the dealer will charge to do the reflash?
Aftermarket tune..Hmmmm, This is only for the PCM right?
I am sorry if I have too many dumb questions...very naive at this
Old Jun 10, 2014 | 06:27 PM
Ltngdrvr's Avatar
Speedo calibration is within the tune.
If your V6 is a manual, tires are 27.7" tall, the track pack tires are 27" tall.
Wheel size has basically nothing to do with tire outer diameters, except that the outer diameter is bigger than the inner diameter(captain obvious ), they come in lots of different sizes.
How much the dealer charges for the reflash depends on the dealer, probably will charge you an hour for a twenty minute job, so $90 to $110 probably.
Old Jun 10, 2014 | 06:37 PM
Can I contact AM with the upgrade and will they be able to help me out with the tune?
i found a nice website that can compare tire sizes and speed difference....
http://tire-size-conversion.com/tire-size-comparison/
Old Jun 10, 2014 | 07:39 PM
Ltngdrvr's Avatar
Yeah, sure, if a aftermarket tune is how you want to handle it.
Their cheapest tuner runs about $380 before the forum discount.
And as I stated above, you then face the possibility of warranty issues.
Old Jun 10, 2014 | 10:25 PM
Thank you for the input my friend! I will need to think about what I should do with it.
Old Jun 10, 2014 | 11:19 PM
Joeywhat's Avatar
The speedo should only be off by 2-3 mph at 70mph, so it's not going to be a huge difference.
Old Jun 11, 2014 | 02:25 AM
OP, you could also step the tires up to 275/40/19. This is a very common and popular size that people with those wheels are running - overall diameter on the 275/40s is exactly 27.7 give it take a tenth depending on different tires. You could see the Pirellis to offset the cost too...just food for thought.
Old Jun 11, 2014 | 07:18 AM
pressman43's Avatar
Thanks......
I always use my Garmin GPS when I want to confirm speedometer accuracy. It seems to work pretty good and you'll know how much it's off.
Old Jun 11, 2014 | 01:44 PM
From what i konw... its 2.2% increase.. so for every 100 actual miles traveled odo will be off by 2.2miles..
Old Jun 11, 2014 | 01:47 PM
This will be an better fix i think.. I will just wait until the tires wear off and buy tires with this size. Thanks you!!
Old Jun 11, 2014 | 01:48 PM
I do not have a GPS as I use my phone for navigation. I think I can install an app on my phone which shows the speed. And then do the comparison.
Old Jun 11, 2014 | 02:14 PM
I believe the Waze app does this, but you have to have it open. But yeah, I'd do some 275/40s when the stock ones are shot
Old Jun 11, 2014 | 04:04 PM
i installed DigiHUD app.. pretty slick..
Old Jun 12, 2014 | 09:45 AM
You all should try DigiHUD app.. I had it installed on my phone and used it its pretty coool. You can even use this as a HUD app. Turn it on in HUD mode let the phone sit on the dash and you can see the speed on the windshield. pretty cool...
Old Jun 12, 2014 | 01:41 PM
Nice, it must invert the text so it shows up correctly on the reflection?
Old Jun 12, 2014 | 02:09 PM
Yes it is... if you are wearing polarized glass loose it....
Old Jun 12, 2014 | 02:17 PM
Jazzman442's Avatar
Thanks......
As part of the installation package the dealer should of told you and did the Change in the PCM. I did the same thing on my Suburban and the Dealer while installing the new tires and rims did the PCM change.
It doe snot take long. It takes longer to get the computer out and connected than it does to update the PCM?
Old Jun 12, 2014 | 03:26 PM
Ltngdrvr's Avatar
Don't think the OP had the dealer doing anything on his car.
And they don't remove the pcm to do anything to it, they only have to hook up to the OBDII port.
