What should I be doing?
Welp I have own my mustang most of its life, it has roughly 34k miles on it. I have always changed the oil with full synthetic roughly around 6k miles.
Any other general maintenance I should do? I know they always try to get you with stuff at the oil change place...yeah i know i should change it myself but when its -10 degrees, ill pay someone to do it.
But they always mention you should do this after such and such miles, kinda makes you wonder or well atleast myself.
Any thoughts or input on other general engine care.
edit: sorry its early and i put this in the wrong area.
Just go by your scheduled maintenance in your owners manual. Dealers and quick lubes will try to sell you every flush and maintenance item they can even if you don't need it
I would check the air filter, maybe now that the motor is nice and broken in get an oil analysis kit from Blackstone or another place and see how your engine is doing with the change intervals and what not.
Like LivingtheStangLife said, going by the maintenance schedule in the manual is all you need to do. Personally, I like getting the coolant flushed every 24 months or so, as well as changing the transmission fluid. If you've got an automatic, that's a bigger deal than with a manual but still a good idea, IMO. Brake fluid wouldn't be a bad idea at the same time for you, since you're going on 3 years old and 34K miles.
I thought this was another oil change thread for a moment...
Depends a lot how you drive the car too - I am looking to change the rear diff fluid soon and may do the tranny fluid as well.
Did you replace the cabin filter yet? Often forgotten, but good to replace regularly... have you flushed the brakes? I bet your fluid could use a refresh. I do my brake fluid yearly.
In some cases, you just have to decide if "old school" maintenance should over rule what the owners manual states.
Case in point: Ford says automatic transmissions have "lifetime fluid", and recommend the fluid be changed at 150K.
I'd prefer to have it flushed every 30K; a pan drop, filter change, and a complete flush.
There's just no such thing as "lifetime fluid", unless they feel that 150K miles is the lifetime of their car.
I beat them at that game all the time! My second ride, a Ford F150, currently has 257K. It has its original automatic trans and engine. Both have not been touched internally.
Still running strong and pulling a trailer on occasion.
The current Mustang is at 57K (2011), and doing fine as well. It will see well into the 200K mark if I hold onto it long enough.
Yeah, clean or replace the CAI filter.
Track Day & Lightly Used Performance Parts
http://www.dgracing56.com
