What is this connector for?
Old Apr 16, 2016 | 11:27 AM
soaringfalcon's Avatar
Nice day out today, so I decided to look over my new to me 2014 Mustang over.
While looking in the trunk, I noticed this loose connector on the passenger side by the spare, attached to the rear of the trunk.
Any idea what option this is for?
Old Apr 16, 2016 | 11:31 AM
Here is the pic that did not attach the first time
Old Apr 16, 2016 | 11:33 AM
I believe it's GT500 related. Either the harness for the second fuel pump or the diff cooler...
Old Apr 16, 2016 | 12:54 PM
SpectreH's Avatar
My '13 GT has this plugged in there....it's the rear parking assist module. CR3T-15K866-AB lists as a 2012 part number, but I assume mine is an early 13 since I bought it in the first week of July in 2012.
Old Apr 16, 2016 | 12:59 PM
Ah! That makes sense. I think there's another unused connector down there somewhere though, for the GT500 fuel pump and/or diff cooler.
Old Apr 16, 2016 | 04:59 PM
LEXiiON's Avatar
Nope. The diff coller connector is above the axle on the outside of the car, and the second FPDM connector is only on the GT500 harness. The GT500 harness is completely different.
The only other connector that might be there for all cars is the Shaker 1000 Amp connector.
LEXiiON
Old Apr 16, 2016 | 06:29 PM
LEXiiON
Gotcha, I must have been thinking of something else then!
Old Apr 16, 2016 | 06:57 PM
LEXiiON's Avatar
Yeah.., don't ask ... I hate harnesses... I need to get an Ecostang surcharge from Stephen
My harness has the Shaker 1000 connector in the trunk (unused). I tied up the differential cooler pump and temp plug to the rest of the harness on top of the axle. Once I install the diff cooler from Stephen it will actually be used.
Ford is using the same harness for multiple versions of the car and some connectors will just hang there.
E.G the GT500 (13-14) only has 2 harnesses. A base and the rest. And if you don't have the track pack you end up with the unused connectors.
LEXiiON
Old Apr 16, 2016 | 09:18 PM
14Glassback's Avatar
So maybe this has been covered before... But if you do not have the trunk sub can you just buy it from Ford and it is a direct plug in?
Old Apr 17, 2016 | 02:24 PM
LEXiiON's Avatar
If you have the connector, then yes. If not then no.
LEXiiON
Old Apr 17, 2016 | 04:10 PM
berzerk_1980's Avatar
LEXiiON
Where would you find it?
Old Apr 17, 2016 | 04:50 PM
LEXiiON's Avatar
On the passenger side in the trunk. Coming out right below the tail light and typically going behind the right side cover (where the BCM is). This is how it looks.
LEXiiON
Gigantor
05-09 Exterior Modifications
Sep 20, 2022 11:12 PM
garya2202@gmail.com
Feb 21, 2018 12:51 AM
TMS Editor
Curated Content Articles 2015-2023 Youtube & Photo Gallery
Oct 11, 2016 02:47 PM
ElkGroveFordGuy
Mar 28, 2016 10:05 PM
kd4gij
Mar 23, 2016 02:48 PM
