What is this for?
What is this for?
The light in between the high beam and seatbelt indicator. Can't find it in the manual. Looks like a car going down a hill with a line through it.
Hill holder(guess that's what it's called) activated would be my guess. If you have a manual transmission it holds the brake for a second or so while you transition your foot from the brake pedal to the clutch if you are on an incline.
Grade Assist. Page 222 in the 2012 owners manual.
Locks out overdrive in the automatic tranny when decending hills to increase engine braking.
I did try the hill assist to see if that lit it up but it didn't, I was pretty sure that was it too.
Thanks for the help Scott.
Yeah this doesn't turn on for the manual transmissions at all. In order for hill start assist to engage, you have to be in gear before you release the clutch. Then it holds the car still for approximately 2 secs for you.
A Man Just Needs Some....
Originally Posted by HizliBullet
If that light comes on it means ur life is going downhill
Yes there is - You hold the hand brake (emergency brake if you like) and as you apply a little power and release the clutch you also let down on the hand brake and bingo you move up the hill without rolling backwards.
