Vehicle Health Report WTF???
Old Jul 8, 2010 | 01:33 PM
stangfoeva's Avatar
MOTM Committee Member
Exclamation Vehicle Health Report WTF???
So I ran a vehicle health report last night using SYNC so I could register on syncmyride.com. Everything was fine except this:
Originally Posted by SYNC Vehicle Health Report
The icons below may be illuminated in your dash or console or may appear in your message center. The vehicle diagnostics indicate a parameter that is out of normal range or that a component has failed. Systems within your vehicle need prompt service and/or inspection.
Urgent
Brake Warning
»What Should I Do?
Check that the parking brake has been released. If the light remains on, the brake system should be inspected immediately. Contact your authorized dealer as soon as possible.
WARNING: Driving a vehicle with the brake system warning light on is dangerous. A significant decrease in braking performance may occur. It will take you longer to stop the vehicle. Have the vehicle checked by your authorized dealer. Driving extended distances with the parking brake engaged can cause brake failure and the risk of personal injury.
»What Is Happening?
Indicates low brake fluid level or a brake system malfunction has been detected.
»What Does This Warning Mean?
Brake system warning light: To confirm the brake system warning light is functional, it will momentarily illuminate when the ignition is turned to the on position when the engine is not running, or in a position between on and start, or by applying the parking brake when the ignition is turned to the on position. If the brake system warning light does not illuminate at this time, seek service immediately from your authorized dealer.
Illumination after releasing the parking brake indicates low brake fluid level or a brake system malfunction has been detected and the brake system should be inspected immediately. Contact your authorized dealer as soon as possible.
Schedule service with your preferred dealership
This dealership does not support Online Appointment.
Online Appointment contacts your preferred dealership to set up a service appointment. In most cases, your Vehicle Health Report data will automatically be sent to your preferred dealer. You can locate a different dealership for service.
I don't get it because there is no warning light on in my dash and the brakes feel fine. Not even a squeak out of them. How accurate is this report? I really don't wanna part with my baby right now I'm just starting to break it in
Old Jul 8, 2010 | 01:52 PM
Lancel's Avatar
Did you have the parking brake on? The first time I ran this I didn't even have the engine on, so you can imagine what I got. I found that the vehicle health report requires the engine be running and that the parking brake NOT be engaged, otherwise it thinks that there's a brake issue.
Old Jul 8, 2010 | 02:03 PM
stangfoeva's Avatar
Oh thank you Lancel. I did have it engaged because I was parked in my garage. After reading the description I kind of guessed that was the issue but I wasn't too sure.
But thats stupid. Seriously they should put a warning up on the NAV screen or something so I would have known not to have the brake on lol
Crisis averted
Old Jul 8, 2010 | 02:04 PM
Lancel's Avatar
Agreed. It doesn't even warn you "Hey, you don't even have the engine running."
20115.0's Avatar
take the parking brake off and itll show nothing
im in torrance, socal. my brother just got a 2010 grabber blue V6 and he likes your car a lot haha
Old Jul 8, 2010 | 02:05 PM
corvettedreamin's Avatar
Ain't technology great?
OOOOH... I know... common sense... let's try that today! Does the car start and run fine? Does it brake as expected? Does it steer as expected? CLUE: It's fine. Don't panic. Chicken Little is on vacation.
When I see a car "system" that can predict imminent brake failure while all systems are working perfectly fine, I'll be very impressed! And I'll see if it can also generate the lotto numbers for Saturday.
Old Jul 8, 2010 | 02:13 PM
stangfoeva's Avatar
I accidentally turned the car off before I ran the report. It said the car had to be running for at least a minute before it could do it. Waiting that minute was brutal lol
Will do. I would have tried that last night when I ran the report, but I didn't check results till 10 minutes ago and I'm at work now. I'm fine now that I know its just a caveat of how to properly do the check.
Tell your brother he can see the car up close as soon as I find a local SoCal meet to take it to
Old Jul 8, 2010 | 02:14 PM
2010MustangGT's Avatar
Something similar has happened to me. I turned the key on, but didn't start the car. Ran a health report and it said my oil pressure and battery were way out of wack. And that I should go to the nearest ford dealer ASAP. But it's cuz the car wasn't running, hence they were not being used- and sat at 0. So just a flawed report of sorts. As when I turned it on the report was error free.
Old Jul 8, 2010 | 02:15 PM
stangfoeva's Avatar
scares the crap out of you doesn't it?
Old Jul 8, 2010 | 02:25 PM
haha, oh man like no other... I was like "WHAT!?!? How can this be!?!?" And had to check it again as soon as I read it making sure I took note of the things that were wrong...
Old Jul 8, 2010 | 02:28 PM
Bert's Avatar
yep, I got that crazy brake warning too . . . it drove me a little nuts at first also, until I read it for the fifth time and saw the part where it says "make sure the parking brake is released"
Old Jul 8, 2010 | 02:32 PM
stangfoeva's Avatar
You and me both man!
Unfortunately I just skimmed the message before posting and skipped right over that part lol
This thread has been very englightening. Hopefully '10+ owners will learn from my mistake and run the health report right before being concerned with the results
Old Jul 8, 2010 | 02:50 PM
newpony's Avatar
I wondering if the Health Report gives you the same information a ODB decoder does?
Old Jul 8, 2010 | 02:59 PM
stangfoeva's Avatar
Here's what it looks like
Old Jul 8, 2010 | 03:04 PM
Lancel's Avatar
Pretty standard stuff really, the most useful aspects of it are the Recalls and Field Service Actions and possibly the Scheduled Maintenance and Dealership coupons.
Old Jul 8, 2010 | 03:08 PM
lolumad
Haha what a dumb procedure to have the car run the report with the parking brake off. What if you live on a hill/your driveway is at an angle?!
Old Jul 8, 2010 | 03:51 PM
stangfoeva's Avatar
lolumad
no kiddin!
Old Jul 8, 2010 | 05:17 PM
wannabe's Avatar
For what it's worth, I don't think it's necessary to run the health report to register on syncmyride. At least it wasn't on the '10 Mustang or Taurus.
Old Jul 8, 2010 | 05:25 PM
stangfoeva's Avatar
that's what it told me I had to do to complete my registration
Old Jul 9, 2010 | 04:33 PM
financialpanther's Avatar
At least you guys get to use the VHF. Here in the Great White North, the feature is unavailable
Not that I really miss it
