Turning off Traction Control during dyno run?
I have a dyno appointment tomorrow, and I wanted to make sure that THIS time around, everything will be perfect. Last time I did the dyno run, I didn't touch the TC button at all. Halfway through the run, the Advancetrac light came on, and stayed on. We had to reset it via a handheld. For those of you that dyno'd the car before, did you guys also see the advancetrac light issue? What can I do to avoid this? Should I disable Advancetrac before the dyno run? If so, what's the best way to do it...hold button down for 7 secs? I heard it doesn't completely shut it off. Can I shut it off via the SCT? What did you all do? Thanks.
So yes, I plan on holding it down for I think 7 or 8 seconds. Was that what you meant? Any other suggestions? What did you do for your dyno? Any other error come up?
That's fair. I'd assume you'd want to get another dyno run. Like mine, you too had a first dyno experience that wasn't ideal. That's why I hope mine tomorrow, will be more "accurate". We'll see.
I do plan on it but dunno when, the dyno shop i took it too which is really the only closest was pricey.
Big-D
Jul 27, 2015 11:24 AM
