TSW Nurburgring Rims
Saw these rims on eBay and they look like the rtr's but are forged. Are the wheel specs below good for our mustangs and what tire size would be good with these? Thanks guys.
Item Specifics
Rim Width: Front: 8.5 Rear: 10.5
Rim Diameter: 19
Offset: Front: +20 Rear: +25
Rim Material: Alloy
Number of Bolts: 5
Bolt Pattern: 5x114.3
You are bidding on a BRAND NEW wheel and tire package of*19"*TSW*Nurburgring RF*staggered wheels. These wheels have*Matte Gunmetal finish and*come*with a*5x114.3 bolt pattern.*The wheels are made with TSW's new Rotary Forged system which allows for a lighter yet stronger wheel. Include a one year manufacturer's warranty against defects.*
Wheel Specs:
Front Size: 19" x 8.5"
Rear Size: 19" x 10.5"*
Bolt Pattern:*5x114.3
Front Offset: +20
Rear Offset: +27
Color:*Matte Gunmetal
** other bolt patterns and sizes available **
Please do not hesitate to contact me for any fitment questions.
Item Specifics
Rim Diameter: 19
Rim Material: Alloy
Number of Bolts: 5
Wheel Specs:
Front Offset: +20
Rear Offset: +27
Item Specifics
Rim Diameter: 19
Rim Material: Alloy
Number of Bolts: 5
Wheel Specs:
Front Offset: +20
Rear Offset: +27
Item Specifics
Rim Diameter: 19
Rim Material: Alloy
Number of Bolts: 5
Wheel Specs:
Front Offset: +20
Rear Offset: +27
I think the offsets are all wrong, if I remember correctly Mustangs are in the low 40mm offsets. Also you don't want to do a 8.5" wide rim on the front as this would limit what size tire you can run on the front on a front heavy Mustang. I wouldn't run anything less than a 9" front wheel, preferrably a 9.5" front wheel.
Dave
Ok I see they have a 19x9.5 with a 41mm offset and 20x10 with a 40mm offset. And what tire size should I use?? 275/40/19 for the front and what for the rear?? Would like to be bigger in the rear.
Dave
Dave
dave
Been talking to a few folks and I think I'm just gonna go with the 19x9.5 41mm offset all around with 275/40/19 tires just like the guys running the RTRs but this should be a bit better cause of the offset not being low like the RTRs.
Also if it is crooked I can't tell, it looks great.
You're right I didn't have an emblem to remove but I removed the stripe. My fear was putting the badges on crooked or not having them even on bothe side which they prob not exact.
