Ticking/rattle in the glovebox area on 2011 GT
Old Jun 26, 2010 | 06:42 PM
Argetni's Avatar
I removed the glove box and traced the rattle (more of a tick/pop) to the lower support bar. I put some velcro pieces between the platic dash part that the glove box attaches to and the metal support bar (also has a ton of electrical grounds attached) and reassembled.
It worked for about 4 miles than it came back, then a bit later it went away again. Really annoying sound.
I am not sure I want the dealer trying to "fix it" as they may scratch the dash or create another rattle.
I am going to buy some foam tape and insulate the hell out of the area which I am sure is just what the dealer would do anyone.
185 miles on the car and it was down to a 1/4 tank left so yes I am enjoying it! Only complaints are the automatic trans (I miss stick) and the glovebox tick/rattle.
Old Jun 26, 2010 | 06:45 PM
GRABOID's Avatar
Only noise I have got is the bushings on the panhard I just put in lol. Didnt hear anything like your talking about though and I have around 600 miles on mine.
Old Jun 26, 2010 | 07:31 PM
06GT's Avatar
Check the plastic behind the door handle...the 05-09 had a notorious problem with clicking/popping from these that is REALLY hard to pin down unless you know about this.
Old Jun 26, 2010 | 07:37 PM
Norberd's Avatar
I hear a similar noise once and a while. It's Left of the Passenger vent (the round one) and above the glove box. Is this the area you're referring too? Nothing too noticeable tho.
Old Jun 26, 2010 | 08:11 PM
Argetni's Avatar
It may be but investigation revealed that it is actually from below the glovebox.
Old Jun 27, 2010 | 01:11 AM
06GT's Avatar
Fusebox cover on the kick-panel?
Old Jun 27, 2010 | 05:38 AM
Stangpilot007's Avatar
I had an occasional clicking sound in my car. I pinpointed it as the left side of the trim above the glovebox. When I held the left side of the trim in it went away. That could just be on mine though... It seems to have gone away though recently.
Old Jul 28, 2010 | 10:15 AM
Skotty's Avatar
Okay...now it's starting to annoy me. Maybe they will issue a TSB. Probably not hard to fix, just hard to pin down the exact source. I need to have my wife drive over the roads where I hear it the most so I can be in the passenger seat and pinpoint the culprit.
Old Jul 28, 2010 | 10:29 AM
cobra97's Avatar
I hear a ticking when the ac is on, appears coming from the passenger side area
Old Jul 28, 2010 | 03:39 PM
2K3 Mach's Avatar
I think I figured this one out
https://themustangsource.com/f726/an...0/#post5917840
NC14GT
Sep 10, 2017 04:47 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
