Ticking/popping
Yep, both times I used Mobil 1 5W-20. I'd change it if it needs to be changed. I guess there are a few guys on the forums that have 40k mi with the tick and nothing bad has happened so far.
The majority of people with the tick (not all) are those who changed their oil before the recommend service interval. No offence to anyone but changing the oil for the first time at 2000miles on a brand new car is just dumb. Absolutely useless. The factory oil has additives in it which help during break in. It is in your best interest to use that oil until its physically time to change it. Using 5w 50 is not a good idea for winter (for those who have actual winters) as that oil is too thick and has trouble penetrating the bearings at the top of the cams (usually where the tick is emitted from). Track pack cars call for 5w 50 because it is assumed the car will be trashed on a track. Unless you are doing so, there is no real reason to use it. The thicker oil usually has different thermal properties which is one of the reasons they recommend it for the track pack.
I remember back in the days when oil change means = every 3k miles. Only with such vehicles as Bmw's would do it at 5k. But back then I had no knowledge of what the full synthetic oil is, I just thought Bmw's and their oil last longer because they are nicer cars.
Question is, why would any car get any kind of abnormal(?) noise after an oil change, why. I have never heard of such a thing as 'you get a ticking noise if you change oil before (or after) recommended service interval' nonsense. - that is until I got the Mustang - can this car be so sensitive.
Speaking of which, what actually is recommended interval for our cars? Is it based on conventional 'synthetic blend' that Ford dealer uses, the Full Synthetic must have different intervals?!
Im not sure about the exact recommended interval but the car can go 10k miles without changing oil no problem. Thats exactly when i changed my oil. Full synthetic always in 5w 20. Since the engine can be problematic you need to be careful when you change the oil, how you change it and which oil you use. Most other cars, this does not apply and i agree with you that its b/s we have to even worry about it.
Question 3 gave me a kick in the *****..what if this was the answer I've been looking for??
video midway down the page
http://www.automotive.com/features/c...Z3Vu9cuNh79c9X
Question 3 gave me a kick in the *****..what if this was the answer I've been looking for?? video midway down the page http://www.automotive.com/features/c...Z3Vu9cuNh79c9X
oh man....I just got this noise over the weekend after changing the oil the previous weekend. 5W-20 Mobil 1, first changed at 2800mi, then changed again at 6k mi. Oil level is good. It happens at low RPM under load. Sounded like an exhaust manifold leak to me because it goes away when the RPM's increase. Man, I guess I now have the infamous ticking noise. So for me it was the 2nd oil change.
You can schedule an appointment online here. Let me know the outcome.
Deysha
Have just over 3,000 miles on mine. Had 2 synthetic 5w50 oil changes. Both were due to timing cover leaks. Not really a choice there. But this is my second season of ownership so I probably would have done it anyway. Unfortunately I have the ticking noise. But will address it with my Dealer again in the Spring. Do not want to waste potential cruise nights remaining with the car torn apart.
Deysha
Have you addressed this with your dealer, BLK STANG? If not, I recommend you bring it in as soon as possible and get it checked out. Also, PM me with your VIN, dealer, mileage, full name, and best daytime number so I can escalate it to the customer service manager for your area if needed.
Deysha
Deysha
Thanks Deysha, I have been out of town for the past few weeks so I haven't been able to bring it into the dealer, but I will be this weekend and we will see how it goes. The thing is, the first time I got an oil change at my dealership at around 4,000 miles I never really had a ticking noise, its just after the second one that its become very prevalent. I remember checking the oil levels and everything checked out okay so not really sure whats going on. Also, the ticking at idle and acceleration only seems to happen when the car is fully warmed up after an hour or two of driving.
Deysha
