For those with 11" rear wheels
Old Aug 5, 2014 | 12:09 PM
kcoTiger's Avatar
Had a really loud noise a couple of times on the way home the other day from the right rear. Pulled the wheel off and found that it had rubbed on the bump stop brace just enough to scrape the paint off. No damage to the wheel but my rear end had migrated to the driver side about 1/8" and caused the rubbing. It would be wise to make sure your rear end is centered under the chassis so you don't experience the same thing. I hadn't thought about it in a long time and wish I'd checked it more often. Just an FYI.
Old Aug 5, 2014 | 07:25 PM
Blown CS's Avatar
Are you going to add an adj panhard bar.
Old Aug 5, 2014 | 07:31 PM
They make bump stop relocation brackets
Do you have the carpet and shock boot removed? Just curious. Also what's your offset.
I'm looking at +59 on an 11" rear wheel.
Old Aug 5, 2014 | 07:41 PM
5.M0NSTER's Avatar
Thanks for sharing.
Old Aug 6, 2014 | 10:47 AM
kcoTiger's Avatar
Offsets are +59. I haven't removed the carpet or the shock boot yet, but it will probably come out during the watts install. +59 is good. I was worried I just had a really tight fit, but all the room was on the driver side.
Old Aug 6, 2014 | 10:48 AM
kcoTiger's Avatar
Originally Posted by 5.M0NSTER
Thanks for sharing.
Old Aug 6, 2014 | 10:50 AM
kcoTiger's Avatar
watts link.
