Stupid question about the diff.
This is kinda basic and I feel like I should know it, but..Can anyone tell me about the design/construction/specs of the 3.55 LSD? Is it a gear-type or clutch-type, etc?
Thanks.
Thanks.
It is the same Trac-Loc differential Ford has been using for many years. It is a clutch-type LSD. It is not really the greatest design, but it's cheap and effective as an LSD as long as it's not abused. There is a way to repack the clutches so it works better, but you will sacrifice with some chatter at low speed parking lot turns.
![Glare](https://themustangsource.com/forums/images/smilies/glare.gif)
The gear type of LSD is the Torsen differential, which is an option on the "base" Boss 302 and I think it's standard on the Laguna Seca. Holds up better to abuse (what it would get on a track).
I think my confusion has been cleared up. My only experience with LSD (no pun intended) up until now has been with the lame-ish, slow-reacting viscous-coupling LSDs in my Subaru. At first I thought the Mustang might have a viscous-coupling diff because it was a "clutch type", but that was just me being confused (a viscous-coupling LSD uses numerous "plates" which I confused with "clutches").
So there are viscous-coupling LSDs, clutch-type LSDs, TORSEN LSDs, etc. The Mustang comes with clutch-type standard and TORSEN is optional on the BOSS. There are definitely some differences in the design and operation of clutch-type vs. TORSEN.
I recall seeing somewhere that the Torsen is available to retrofit to the GT from FRPP catalog, as a complete axle assembly, for around $1500-$1600.
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
PICS
