Squeak After Lowing Car, Need opinions
Old Apr 14, 2015 | 07:21 AM
2012White5.0's Avatar
"Bird Chirp" squeak after lowering with Koni's
Just lowered my car with a set of the Koni STR.T and Steeda Sport Springs. I also put in new sway bars and couldn't be happier with the performance, but I now have a squeak that was not there before lowering, and is getting worse and worse!
Could this be defective struts?
YouTube Video:I was shaking the car from the door frame as my wife took the video.
https://www.youtube.com/watch?v=xcjg...r#action=share
Old Apr 14, 2015 | 08:30 AM
JSmies's Avatar
I just went through what you are experiencing. For me, I had a bad Koni strut that was just installed. It sounded like a bird chirp whenver I hit a bump. My noise was coming from only the drivers side
My setup was with Ground Control Plates, H & R springs and Koni SRT.T struts and dampers.
Old Apr 14, 2015 | 08:45 AM
Thats exaclty what mine sounds like. Do you mind telling me what you had to do to get it resolved? I have the Ground Control CC plates also. Love the setup, just not the squeak.
Old Apr 14, 2015 | 08:51 AM
Coyote5-0's Avatar
I installed lowering springs and have a sqeak/creak when going over bumps. Another forum member had the same problem after lowering and it was resolved when he replaced the factory strut mounts. They can easily be damaged during spring removal. Not saying that is guaranteed to be your problem, but its a possibility.
Old Apr 14, 2015 | 09:12 AM
Replaced mine with the ground contol CC plates. I has ordered a set of adjustable swaybar end links but they were on back order, It looks like the end links will be here this week, so we will see if that does anything. I had access to a lift on Saturday, and didnt want to waste the opportunity.
Old Apr 14, 2015 | 09:51 AM
JSmies's Avatar
I had Koni send me a replacement strut. My strut was purchased in February so it is possible that they had some issues in production.
Old Apr 14, 2015 | 01:10 PM
BLK STANG's Avatar
I have very nearly the same problem. Lowered on sportlines and I am almost certain its the stock strut mounts. Every time I go over a bump at slow speeds I hear a similar creak coming from up front
Old Apr 14, 2015 | 01:34 PM
~KING~'s Avatar
Had the same happen to me, bad Koni strut (SRT.T). Bought from AM; after confirming the chirp/squeak was coming from the strut they sent a replacement.
Problem solved.
Old Apr 14, 2015 | 04:33 PM
Problem solved.
How did you confirm the squeak? I took a video of what is happening. Bought mine from AM at the first of the March.
https://www.youtube.com/watch?v=xcjg...ature=youtu.be
Old Apr 14, 2015 | 10:50 PM
~KING~'s Avatar
How did you confirm the squeak? I took a video of what is happening. Bought mine from AM at the first of the March. https://www.youtube.com/watch?v=xcjg...ature=youtu.be
At first I was getting the squeak from the passenger's side strut. I switched both front struts but left the GT500 mounts and springs in their original locations/positions, after doing this the squeak "followed" the faulty strut to the driver's side.
Old Apr 15, 2015 | 04:39 AM
I sent AM the video and called their customer support, and they are sending me new ones. They said that they have seen this a few times with struts purchased around the time I bought mine. Both sides are doing it on mine, but the driver side is twice as loud. I disconnected the sway bar end links to make sure that was not the issue. The struts were very had to pull out to full extension when I first received them.
Glad I was able to get some great customer service!
Old Apr 19, 2015 | 11:35 AM
choate's Avatar
Weird thing is mine did this right after install. I had a shop I trust install it and they said it was super easy. Like an hour and a half job tops for them. Anyways I took it back and had them push on the passenger side fender right about the tire and you could hear something rubbing or something. It was making a squeaking noise. I drove it for a couple weeks and before I called autoanything which is where I purchased mine and next thing you know I forgot about it b/c the noise stopped. Been on them for probably 25k miles since and no noises
Old Apr 19, 2015 | 11:57 AM
JCStang's Avatar
If God meant Mustangs to be low, He would have.....
Old Apr 19, 2015 | 12:08 PM
momogt's Avatar
I have the same issue. But its coming from the rear of my car.
Old Apr 19, 2015 | 03:23 PM
Well I've checked everything. I even took the endlinks off to and shook the car to make sure it wasn't the swaybar. I used some spray white lithium grease on the lower strut shaft and let it sit overnight and it has helped quiet it down. At least now it's somewhat bearable.
I don't think it's the strut mount since I used the ground control cc plates, and I haven't seen anyone complain about them.
I've gotta wait 3 weeks for replacement struts, so we will see how it is by then.
Old Apr 19, 2015 | 03:44 PM
2014GHIGGT's Avatar
So sorry to hear about your squeak. A bummer for certain.
Old Apr 21, 2015 | 02:25 PM
choate's Avatar
I think mine might have been from the brand new springs seating onto the brand new rubber mounts. Hope a new strut fixes it for you or maybe it will just go away like mine did in a couple weeks
Old Apr 21, 2015 | 06:41 PM
So today was an abnormally cool day (about 65) so I took the stang for a drive. For the first 15 mins there was no squeak, nothing! The longer I drove and as the car heated up the worse the squeak got. Also, it is quiet during compression, and only seems to squeak when the strut rebounds.
Old Apr 21, 2015 | 08:40 PM
jp1seattle's Avatar
It's the strut. Trust me.
Old Apr 21, 2015 | 09:00 PM
choate's Avatar
Don't they have a million mile warranty? Or did I dream that up
