SCT Datalogging glitch or failing sensors
Old Jul 10, 2022 | 02:19 PM
hamiltankk's Avatar
I was datalogging my 2011 Ford Mustang GT with the SCT X4 device and livelink, this is the Stock PCM tune, and on two different data logs I got huge spikes in the knock sensor reading a max value of 1238.25 and measured afr bank 2 reading a max of 46.50 (at a different time of knock "glitch").
I used Forscan and it has two PIDs for the Knock 1 and Knock 2 sensor, and I do notice one sensor is about a value of 100 always higher than the other one. Forscan shows Knock in values of 0 to 3000 instead of degrees, so not sure what the Forscan values actually mean.
Are these events a wideband sensor and knock sensor going on the way out, wiring issue, etc, or a glitch with SCT datalogging device?
Thank you
File Type: csv
File Type: csv
azoufan
Jun 16, 2015 02:18 PM
Stormbringer
Jan 18, 2012 04:23 PM
Blackout
1994-2004 V-6
Sep 5, 2011 10:17 AM
SonicGT
Feb 21, 2006 07:41 PM
