Scratch on the paint
Old 11/15/15 | 03:34 PM
trackpack13gt's Avatar
I noticed there is a scratch on my rear quarter. It is not a deep scratch but I can see the primer underneath, is it possible a body shop can buff this out?
I am also thinking about fitting oem side scoops how much should I pay for a bodyshop to prep and paint them?
Old 11/15/15 | 04:12 PM
dusman59's Avatar
I think you can get them prepainted. It should be cheaper than a body shop as most shops won't dirty a gun for less than $200.
Old 11/15/15 | 04:58 PM
I know AM sell very similar looking ones but reviews mention how you can see the double sided tape, where I guess the oem ones they have a deeper channel for the tape.
Old 11/15/15 | 06:04 PM
JCCNY's Avatar
All I see is a ghost giving the thumbs up lol. It doesn't look that bad and a good detailer can probably buff it out or at least make it hardly noticeable. If you have a rotary or DA polisher, try it yourself.
Old 11/15/15 | 06:09 PM
Nope, I don't have a buffer and don't trust myself with one.
Old 11/15/15 | 06:19 PM
Joeywhat's Avatar
An orbital is stupid easy to use and almost impossible to screw up the paint with it. I mean, I guess you could drop it on the car or something...A decent one will likely cost about as much as a proper repair, plus you can use it to keep the paint looking nice and swirl free. I bet with a good polish regimen (start fairly course, go to super fine) that scratch will be barely noticeable. After that, just use one of the finishing polishes on the rest of the vehicle, assuming the paint looks good save for some swirls here and there.
Don't forget to wax and/or seal the paint after polishing.
Old 11/15/15 | 07:05 PM
88lx50's Avatar
That's not deep. It will buff out. Learn how to use a machine as there will always be scratches to buff out. Like Joey said, an orbital is almost goof proof.
Old 11/16/15 | 02:19 PM
JonsMustang's Avatar
Rubbing compound and you're good to go.
Old 11/16/15 | 02:33 PM
Actually I do have one back home come to think of it, I tried to use it on the piano black decklid to remove the trace of a dealer decal, it just left swirls on it....Hold on it does not work on plastic right???
Old 11/16/15 | 02:38 PM
Get Meguairs Rubbing Compound. It just takes surrounding paint and covers up the sratch or you can get QUIXX scratch repair kit, comes with everything you need.
Old 11/16/15 | 04:37 PM
Joeywhat's Avatar
Plastics require different compounds to remove scratches and swirls. Generally paint polishes do not work well on plastic.
I also tend to do plastic by hand as it's much easier to heat up which can cause issues. An orbital is unlikely to produce enough heat, but some plastics can warp, discolor and otherwise become damaged at rather low temps...much lower than what paint/clearcoat can handle. This doesn't apply to plastic body panels, just trim pieces and whatnot. Sometimes different (and much cheaper) materials are used for those.
Old 11/17/15 | 05:40 AM
David Young's Avatar
I've removed worst scratches than that, using '3M scratch remover'.
Old 11/18/15 | 04:07 PM
must....resist....temptation.........to.....chime. ...in.......on.....threads.....about.....buffing and detailing.
CRAP! I responded. Ugh. It's like a drug to me.
short answer: buffable.
long answer: buy a GOOD DA/buffer and do it yourself. That scratch would take me 5 minutes TOPS to remove. I wouldn't even charge you if you came to me, like one of my clients.
Old 11/21/15 | 10:03 AM
backin15's Avatar
I had a similar scratch, I buffed it out with Meguiars #2 fine cut cleaner, then followed with #9 swirl remover and a coat of wax. It came out great!
C Moe
3/16/16 09:52 PM
Crumpler
Deep Impact Blue
12/27/15 07:11 PM
trackpack13gt
11/13/15 03:07 PM
