Satellite antenna wart...
Old May 22, 2010 | 12:55 PM
Ltngdrvr's Avatar
Premium Mustang owners, how does the satellite antenna mount to the decklid, is it just a stick-on mount or does the decklid have a hole for it?
Old May 22, 2010 | 01:02 PM
YSUsteven's Avatar
The only way it would be stick on is if it was not connected to anything. It would not be an antena if it wasn't connected to anything, now would it.
Old May 22, 2010 | 01:03 PM
Well if it's like the others I've seen, it's both. Stuck on with a hole for the wire. It's gotta attach to something!
Old May 22, 2010 | 01:11 PM
Another option I've been toying with (if it can work, and only if I didn't get a Glass Roof car) would be to get one of the Lincoln antennas from the MkS or MkZ. They are painted body color, and I believe they incorporate both the radio and sat antennas. Also, the Lincolns come in most the same colors as the Mustangs do, so you could possibly get one already painted in your color. You could either replace the black trunk antenna with one painted the same color as your car and keep the standard radio antenna, or maybe even remove the standard radio antenna and incorporate both into the new antenna (still on the trunk). If you're really resourceful, you may be able to incorporate both radio and sat into a painted antenna, then move it to the roof where it's less noticeable (and have the trunk and fender filled and shaved), but this would obviously cost the most. Just some options to think about. I've put a lot of thought into this too, and studied a bunch of different Ford products to think of options.
You could even have both shaved and stick them under the window/windshield. I have an Alpine stick-oh antenna that mounts across the inside of the windshield. It works great, but they are discontinued...
Old May 22, 2010 | 01:27 PM
coffeejolts's Avatar
Couldn't we paint the antenna wart to make it a little less noticeable? I've seen plenty of gps / sat radio antennas that come painted.
Ltngdrvr's Avatar
Thanks for the smartass answer.
I had a external cell phone antenna on my 18 wheeler that stuck on the outside and had another part with the cable that stuck onto the inside and the signal passed through so no hole was drilled. Thought it may have been possible for it to work that way in the fiberglass decklid.
I have since found a picture of the antenna not mounted to the car and it does go through a pretty fair sized hole in the decklid.
Too bad, was hoping for something easier to move than that.
Old May 22, 2010 | 01:33 PM
YSUsteven's Avatar
Your welcome...
Old May 22, 2010 | 01:34 PM
Ltngdrvr's Avatar
Painting the wart would work for non-metallic paint but I would worry that metallic in the other paint colors would interfere with the signal.
I would think that moving the antennas to the inside windshield area would be the best answer but would leave two holes in the body to be filled.
Here is a inside mounted radio antenna: http://www.thehoffmangroup.com/autol...sso?itemid=HAB
Old May 22, 2010 | 01:40 PM
Chad's Avatar
The satellite signal goes through glass. I currently drive a Sebring, for the next few weeks anyway and I have my antenna mounted under the dash, hidden out of site. The windshield on the Sebring is rather large, on a sloped angel that provides a clear sat signal. A glass roof car may work and enable you to hide the antenna within the car.
Old May 22, 2010 | 01:46 PM
Skotty's Avatar
Personally, I think it would be more noticeable if painted body color.
Old May 22, 2010 | 02:07 PM
Ltngdrvr's Avatar
Since the antenna cables for both antennas are already to the back of the car it would seem that inside the rear glass on the deck behind the seats would be the place to mount both antennas. Minimal amount of cable chasing required. I would just mount the stock satellite antenna there and get one of those hidden antennas for the regular radio and put it in there too and splice the cable from it to the stock antenna cable.
The only thing that would keep that from working would be if you had an aluminum rear window louver on the car.
Old May 22, 2010 | 02:17 PM
montreal ponies's Avatar
Do Lincolns come in Sterling grey ?
Old May 22, 2010 | 02:19 PM
Overboost's Avatar
It might be worth asking a company like Visual Garage to make a painted slip cover for that wart that would stick on the OEM one. They do sharkfin antennas and the quality is fantastic. I could see them making something, but only if it would fit several vehicles.
Old May 23, 2010 | 01:38 PM
wingless's Avatar
The first mod I'm going to do to mine is to remove the factory antenna and replace it with this one.
Old May 23, 2010 | 04:45 PM
hawkeye18's Avatar
An invisible one?
Old May 23, 2010 | 05:38 PM
Ltngdrvr's Avatar
Originally Posted by hawkeye18
An invisible one?
No, not invisible, it's a square with a little red x in it.
Don't know how that's any better than the wart...
Old May 23, 2010 | 05:51 PM
wingless's Avatar
Computers suck!
It would look fine when I pointed to the image, but go to a red X when I posted the reply.
The image is now re-hosted on my photobucket account.
It is not funny anymore!
Old May 23, 2010 | 06:06 PM
Ltngdrvr's Avatar
Can you get one of those without Al Franken?
HizliBullet
GT350
14
Nov 14, 2015 08:59 AM
mrp5150
Aug 23, 2015 06:29 AM
302 GT
Aug 21, 2015 07:31 PM
hawgman
05-09 Interior and Audio Mods
67
Jan 8, 2007 01:31 PM
