Rust making Axle Back and Mid Pipe Stick
Old Nov 15, 2014 | 10:37 AM
mkj5013's Avatar
i'm having trouble getting my stock exhaust to separate from the mid pipe after i removed the clamp due to some rusting. Any suggestions on how to loosen it up? I've been crankin it pretty good and its not coming off and I dont' want to break anything.
Old Nov 15, 2014 | 11:06 AM
NacsMXer's Avatar
Try heating up the joint with a propane torch or spraying some penetrating oil in there.
Old Nov 15, 2014 | 12:55 PM
mkj5013's Avatar
I already tried wd40 and it didn't seem to do much. I'd have to try to get a torch since I don't have one
Old Nov 15, 2014 | 09:12 PM
Cdvision's Avatar
Give it a whack with a rubber mallet. That should break it free.
Old Nov 15, 2014 | 11:17 PM
Joeywhat's Avatar
Use a good penetrating oil, not WD40.
Old Nov 16, 2014 | 12:03 AM
mkj5013's Avatar
i'll have to pick some penetrating oil up then. I'll need it for when i actually replace the axle backs. This was just so I could spray them with some high temp paint and change the look of the stock exhaust a bit. The rubber mallet didn't work but i didn't have much room to work with so that could be part of it. The clamp to keep the midpipe and the axle back was in the way to get a direct shot at the joint and with my lack of space, i was having trouble opening it far enough to remove it completely.
Old Nov 25, 2014 | 08:27 AM
Critical Mass's Avatar
WD40 is a degreaser. Not an oil.
Old Nov 25, 2014 | 11:55 PM
TommyV's Avatar
"WD-40® Multi-Use Product protects metal from rust and corrosion, penetrates stuck parts, displaces moisture and lubricates almost anything. It even removes grease, grime and more from most surfaces."
Old Nov 26, 2014 | 07:32 AM
scott9050's Avatar
http://www.jalopyjournal.com/forum/t...owdown.350800/
MRGTX
2007-2009 Shelby GT500
Jan 2, 2024 04:30 PM
Ecostang
Nov 3, 2022 08:50 PM
Andy11859
Which is Better
Sep 10, 2015 12:07 PM
glo106
Aug 11, 2015 08:29 AM
