Redline MTL 70W80 Gear Oil for MT82 owners
I'm starting to rack up the miles on my 2012 GT, so I decided to search around for possible motor, tranny, and gear oils. Stumbled across Redline MTL 70W80, which is described by Redline to be a replacement for the Motorcraft XT-MT-QS fluids that is spec'd by Ford and shipped in (most of) our cars. See: http://www.redlineoil.com/product.aspx?product=50204
Has anyone with more technical knowledge of the Redline MTL 70W80 looked at the specifications and determined if it is indeed a good replacement for the stock QS fluid?
I've had it in mine for about 1000 miles now. I like it. I also put this spec sheet together for the different oils...
https://spreadsheets.google.com/spre...thkey=CObIs8wM
Agreed.
It does just fine. Others on AFM have used Amsoil Synchromax with similar result to Redline MTL. Its very close in composition to Redline.
Evil_Capri
9/11/15 08:39 AM
