The reason why the Induction Sound Tube is good
And why you should leave it on, at least on a stock Mustang, and pull the baffle out of the firewall end of the tube.
My car, all stock, still has the stock mufflers, just the baffle taken out of the sound tube.
http://www.youtube.com/watch?v=XRsYh...ature=youtu.be
Makes for a pretty good interior sound at WOT, at least I think it does.
There are two foam baffles, one right behind the diaphragm-looking part and one on the end of the tube at the firewall. I tried pulling both out and found the noise a bit too 'harsh'. I found that pulling just the baffle on the firewall side is perfect.
That way it only sounds off when you put your foot in the throttle.
Porcshe has a engine sound transmitting device on the new 911 Turbo too.
It really just amazes me how harsh some peoples feelings are about such a simple deal like this.
I like the sound it pipes in and so do a lot of others although they may be afraid to admit it for fear of all the ridicule they hear over it.
Maybe it is, maybe not, don't know anything about a m3.
I know what you're saying but it's not synthetic... it's the actual sound of the engine but with the superior cabin insulation in cars these days you don't get to hear them anymore. Plus it's already there vs. a $400 - $700 axle back exhaust system. My '66 GT is super loud inside and out. It's just a little metal box so you can't help but hear the engine. And everything else...
?? Intake is part of the engine... More to "engine" noise than exhaust. In fact, the reason different engines have different exhaust notes (e.g. small block vs big block modular vs pushrod and different car makes) is that the engine itself through it's design has it's own unique sound. The exhaust is just the exit point for said sound.
Apples to oranges. Once again, exhaust is just the exit point. The engine has it's own unique sound for many reasons as mentioned before. To spare beating a dead horse, if the intake portion of the engine makes no sound, where is that noise in the sound tube coming from...?
And there is plenty of sound coming from where the air goes into the engine.
The attitudes toward this simple sound transmitting tube just boggles my mind, SHEESH!!!
Well, at least for the flute, you are wrong. The sound from a flute comes from the air passing over the mouthpiece. Have you never seen someone playing a flute? They blow air across the mouthpiece opening.
You may not believe me or agree. That's ok too.
Correct, it exits through the exhaust. You can put the exact same exhaust system on two different types of engine and they won't sound the same with the exhaust being the constant. Hence (for my point at least) it's not the exhaust that is generating the unique sound, it's the specific engine. That's all I meant. Put dumps on one car and factory exhaust on another with the same engine and they will also sound different... Only because the exit is now different.
