Realtime Fuel Economy in Message Center, what is the scale?
Does anyone know what the actual scale or mpg (or L/100km) per bar is represented on the Realtime fuel economy display in the message center?
First off; I'm as dumb as a rock & really not even sure what you are talking about. Is this about that 5 bar levels thing? I think that just says how you're driving, not in MPG? Like if I'm driving on flat road, just on cruise so no pedal; it's on on all 5 bars. As soon as I put foot in it, goes down to 1 bar. Sorry.
What you do is set the car for the MPG reading and use the cruise control. Clear the mpg and let it settle on an open level road. Once it has settled to a steady mpg reading, then click the select button to change to the graph bars. I did that several times and think each bar set is about a 10 range on mpg until you get to the last graph...it can go much higher based on the fact that it is the last bar set.....
Been a while since I did that so you might come up with a slightly different answer. Also, remember there seems to be a built in error in the mpg numbers reading being a bit high.
The bar graph? I think its like the old vacuum type gauge that i think i saw on Chrysler products in the 1960"s (i know, i'm old or is it ). If you kept the needle on the 'green' you were getting the best gas mileage.
It's not a reverse tach, it's a vacuum gauge. More throttle = less vacuum, and therefore, theoretically, less MPG's. It's not really telling you anything that you couldn't glean from your foot position on the gas pedal.
Not even a true vac. gauge either since it gives no reading if you are not moving.
