Rattle in drivers door with music
Old Feb 14, 2011 | 12:41 PM
ShaneGT's Avatar
anyone else have this issue, my drivers side door rattles whenever bass is played. i have the shaker audio package btw. i just want to see if its "normal" and if i have to dyno mat it to get rid of it. if not , back to dealership..
thanks
Old Feb 14, 2011 | 02:40 PM
ssimaniac's Avatar
I have the shaker 1000 and everything rattles when the bass is on. I would never get the package again since the rattles are very, very annoying. I won't take it to dealership since they will mess it up more. I find my settings that somewhat work.
Old Feb 14, 2011 | 02:56 PM
Norberd's Avatar
I've found the map pocket sometimes rattles but only on certain songs. Aside from that the car is rattle free. Maybe I don't crank my bass enough...
Shaker 1000 as well btw.
Old Feb 14, 2011 | 02:58 PM
ShaneGT's Avatar
well on my normal rock music.. i have no problem, i noticed it when my wife put on some rap...
Old Feb 14, 2011 | 06:18 PM
MyStang2010GB's Avatar
i had the same issue. There is a TSB for this. the rattle is from the door lock / window switch plate. the fix is to add some foam tape under the switch plate. Worked on mine!!
Old Feb 14, 2011 | 06:21 PM
David Young's Avatar
I had a bad rattle and it was a mini umbrella i had in the bottom storage of the door.
Old Feb 14, 2011 | 08:05 PM
Fire512's Avatar
I get a rattle in the passenger door. It doesn't happen all of the time buy it's definitely from the bass. If I gently pull on the door pocket it stops. I'll eventually bring it in for it.
Old Feb 14, 2011 | 09:12 PM
Try just touching the switch plate the next time just to ensure it isn't that. Additionally others have stated that the screws that hold the subs into the door panel have been silly loose causing rattles.
Old Feb 14, 2011 | 09:15 PM
2010MustangGT's Avatar
Link to the TSB?
Old Feb 14, 2011 | 09:42 PM
Originally Posted by 2010MustangGT
Link to the TSB?
I'd have to google it and dig for it....
Old Feb 14, 2011 | 10:54 PM
Yea I mean I just went off this site: http://www-odi.nhtsa.dot.gov/tsbs/
If you can find one- cool, if not, no biggie.
BTW, what happened to the grabber blue?
Old Feb 14, 2011 | 11:45 PM
neevers1's Avatar
I had this, until I took whatever was rattling out of the door cubby hole.... Might want to check it out, I was pretty annoyed until I figured it out. No more rattle.
Old Feb 15, 2011 | 12:12 AM
2011 GT's Avatar
Was the umbrella still attached to a cherry and slice of orange??? (Just kidding)
I have the same rattle and can't figure out where it comes from... it almost appears that it comes from the upper part of the door panel, about midway. I don't play the music crasy loud, and the rattle is still noticable. However, there is no rattle otherwise, e.g. driving on rough surface roads, etc. So it must have to do with the speaker or pressure due to the bass in the door... don't know??
Old Feb 15, 2011 | 06:17 AM
ShaneGT's Avatar
thanks, ill check this out!!!
Old Feb 16, 2011 | 01:53 AM
2011 GT's Avatar
Searched for the TSB, but couldn't find it anywhere... any suggestions?
Old Feb 16, 2011 | 05:24 AM
My rear view door mirror was rattling. Poped the glass out and tightened the screws behind it and all was good after that
Old Feb 16, 2011 | 06:00 AM
Here is one of them that discusses the map pocket in the door:
TSB 09-12-7
TICK/POP/SNAPPING/BUZZ NOISE FROM DOOR PANEL WHEN OPERATING AUDIO SYSTEM - VEHICLES BUILT BEFORE 5/1/2009
I would disregard the built before date if this is the exact issue you are having. The one that fixed mine had similar dating and it was for the window switch plate but that was the exact issue..
Old Feb 16, 2011 | 06:14 AM
I can't find the TSB from that site, it only listed (2) for the 2010 Mustang and they were mostly safety related.
The Grabber Blue i had to sell when I got custody of my kids from my crazy ex-wife. I needed a 7 passenger vehicle. We sacrificed the stand because i did not want (2) $500 a month car payments. In hind sight I could have done it because my work picked up tremendously about 4 months afterwards.... so here I am again with another stang.
Old Feb 16, 2011 | 06:19 AM
ShaneGT's Avatar
i found the tsb, but its onnly for 2010 models...
Old Feb 16, 2011 | 01:02 PM
FivePointO's Avatar
I have the Shaker 500 and my doors have annoying shakes and vibrations at certain frequencies. I thought about pulling the door panels off and putting some kind of dynamat to get rid of all of it. One thing is they mounted the lower speaker to the door panel instead of the door itself. I guess "shaker" should be taken literal.
I do turn the volume up on the stereo full blast often, but I still should not get annoying vibrations from time to time at low volume.
