Prothane motor mount fit
Does anyone know if the motor mounts from Prothane for the 2005-2009 car are the same as the ones for a 2012 GT? Everywhere I look I can only find ones listed for 2005-2009.
Thanks!
Thanks!
So, for anyone wondering, the mounts for a 05-09 are the same as the 11-12.
The only thing is you'll want to use longer bolts to secure the engine mount bracket to the motor mount. The ones that came with would have only engaged about 3/8".
The prothane mounts have a little over 1" of thread, I think it would be wise to use it.
I'm surprised im the only one here using aftermarket motor mounts
I had them on my '06 GT. Had to install them after my LT install. Did discover that they actually raised the engine about 3/8", caused a problem with my Shaker scoop, so I had trimmed them down. Should not have any problems with the stock intake.
Do not have any reason to install on my '12.
Good post that the 05-09 & 10-up are the same. Gives you more options to buy from.
Feb 10, 2017 07:12 PM
Sep 16, 2015 06:44 PM
