pirelli tires
pirelli tires
My 2010 Gt has now got a little over 4000 miles on it and it seems to be losing its initial quiet. Wind noises exist which were not noticeable when new and most annoying of all the 19 " Perellis are beginning to sound loud just like the original 17's on my 05 . They were quiet at first but now seem to have an annoying "thrum " sound when you are coasting down and at speeds around 50-60 mph. A dealership tech took a ride with me today and he heard it too . Is anyone else having anything similar and if so what have you done ?
Karrnutt, I don't have an answer regarding the tires but I've got a question for you. I see that your 2010 has the glass roof. I think they look beautiful in photos but I don't believe I've seen one in person. I'm just curious to hear your opinion on it. Are you glad you have the glass roof? Any downside?
Randy
Randy
Randy
Randy
I have Pirelli P Zeros N spec on the Porsche. As they wear they do get louder, in fact it got so bad on the freeway it began to annoy the hell out of me. My next set on the PCar I'm going to give the Nitto Invos a shot.
Dave
Dave
I've been reading a lot of good reviews on the Nitto Invos. I think they look pretty good too.
Took the car to a Pirelli dealer today and his first words were , "Are they howling ? " They put her on the hoist and did a visual inspection .Told me they couldn't see much wrong exept they were under inflated and the fronts were starting cup on the inside. He said they work best when inflated to 35 to 37 pps. The alignment is my fault due to lowering , but I wanted to wait till the springs settled .It goes to the dealer for alignment tomorrow. I'll give it some time to level out the front tires and see if it improves. If not, back to the tire shop. He didn't seem to suprised to me, so I think they are aware of this problem . Oh, and I threw away my digital tire guage !
Thanks.
Underinflation greatly affects most tires, doubly so for the Pirelli's. And remember that 32psi at 60 in the shade isn't 32psi at 80 in the sun after you've been driving for half an hour.
I think they walk all over the factory Pirelli's. They grip in the turns much better I don't think I have pushed them to their limits yet and I've tried a few times. I've have had them for a few months and I have 255/35/20 Where the pirelli's lost traction and plowed during turn ins the generals just gripped.
Dave
I run Nitto NT555s on the street. I'm considering getting a set of NT05s when they are done.
Nitto NT01s for the road course.
Can you tell I like Nittos?
Had the front end aligned at the dealer ,even after lowering it was out very little . The alignment did seem to help. I'll have to wait and see if things smooth out .
I've got the UHPs in the same 255/35-20 size, I like them quite a bit. Never did have anything else on it, though, so hard to compare, pulled the OEM 18" BFG's off the first week.
Have done two HPDEs this fall, one on a fairly abrasive surface, and they held up well, better than I though they would. Bit of cupping on the peripheral tread blocks, but not bad, no noisier now than before.
Look good, ride fairly well for that size/profile, but do trhum on certain surfaces (mostly concrete) at certain speeds. Smooth freeway, though, they're quiet as can be. With aggressive cornering like on the track, they do howl, but never squeal. Trying to decide to stick with them or go to the Hankook Ventus once they wear out (and they're not wearing much at all so far). Regardless going to go to a 275 all around.
