Panhard bar question
Old May 24, 2011 | 10:57 AM
aujang's Avatar
Getting some suspension work done on Friday: lowering springs, and front and rear sway bars. I'm on the fence about adding an adjustable panhard bar. How much better steering response should I expect from adding the panhard bar? TIA.
Old May 24, 2011 | 11:27 AM
YSUsteven's Avatar
I would guess that you you not notice any change in steering response as the panhard bar is not attached to any steering component.
Now, in all seriousness, I would expect that the feel during cornering would be better, but I don't have any experience here. I would be interested in what others think about it improving cornering feel. It might even be necessary depending on how much your car gets lowered.
Old May 24, 2011 | 11:34 AM
JimmyM's Avatar
It's mostly to center the rear after you lower the car, iirc
Old May 24, 2011 | 12:40 PM
Modshack's Avatar
Exactly...Your axle will be skewed to the left. If you want consistent handling, it's best to have the axle centered. Mine moved 3/8ths of an inch with a 1" drop.
If you want REAL consistent handling, go with a Watts link.
Old May 24, 2011 | 01:15 PM
aujang's Avatar
Woah! The rear will be dropped more than an inch.
Thanks for all the replies.
Old May 24, 2011 | 01:24 PM
Modshack's Avatar
Than you'll likely need an adjustable PH bar. Measure after the drop to confirm.
Old May 24, 2011 | 02:42 PM
CO_VaporGT_09's Avatar
Buy mine! Special $80 shipped just for you!
https://themustangsource.com/f722/fs...e-s197-495607/
The stiffness of the aftermarket ones also gives a bit better consistency. But as stated above, Watt's is the best!
Old May 24, 2011 | 06:50 PM
mystickeith50's Avatar
This. It is almost a must on our car. Mine moved a half inch with my drop.
Old May 25, 2011 | 05:40 AM
aujang's Avatar
Thanks for all the feedback. I'll be going with the panhard bar. Want to just do it once and do it right. Cheers!
Old May 25, 2011 | 10:07 AM
jlc41's Avatar
I think you may want to reasrch Watt link and Panard bar to compare the two before you commit.
Old May 25, 2011 | 10:09 AM
aujang's Avatar
I will. Thanks.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
RoushRS3
Sep 29, 2015 08:03 PM
Evil_Capri
Sep 25, 2015 12:56 PM
