It's a pair. Decent price for a set. Cheapest I've found is $702 each from a dealer.
prices on these tail lights should come down drastically after some more 2013s hit the market. remember, every model (including v6s) come with them, so they're going to turn up in wrecking yards, etc
if you're looking for OEM 2013 rear lamps, i think patience is virtue |
Right now I'm looking for part numbers for the bumper cover lower extension and the license plate surround.
FYI part numbers for the 2013 GT500 rear bumper is: DR3Z17K835APTM
and in case they haven't been posted, the 2013 tail light part numbers are: DR3Z13405A / DR3Z13404A |
Originally Posted by HizliBullet
We need the bumper to fit 2013 tail lights which is a bummer I found the license plate panel but don't have a part number yet. Cost is $66. |
Does anybody know the part number for the "13 GT/CS front bumper splitter? I want one.
Also, the part number for the '13 Boss rear bumper diffuser? |
(Post 6344587)
You need the whole rear fascia to put the insert in. DR3Z-17F828-AA. No idea on cost.
or....I can wait for the RTR rear bumper cover which is REAL nice! |
Here's some more part numbers I was able to deduce:
Rear fascia without diffuser: DR3Z-17K835-APTM License plate surround: DR3Z-17B390-AA ($66.45) Boss 302 Lower bumper extension: DR3Z-17F828-AA GT500 Lower bumper extension: DR3Z-17F828-AB GT500 quad tip exhaust: DR3Z-5230-L and DR3Z-5230-M ($301.75 each) I still can't get pricing for the diffusers, but I did get the mufflers now, and am considering the GT500 lower diffuser, 2013 GT500 mufflers, and Boss H-pipe. |
Originally Posted by Red Razor
(Post 6258551)
I didn't see this mentioned in this thread. Wanted to express interest in adding the boss rear lower valance and front splitter to a 2013 GT. The rear valance appears to be a bolt-on.
1 Attachment(s)
I am Interested in the Pont Puddle Lights, I need a Part Number..
All I have is this.. I need the Prefix and Suffix numbers for a full part number. Attachment 209622 |
(Post 6292635)
Shaker and Track Apps are not the same thing. From what I've learned, Track Apps require a lot of harness modifications, which will cost a boatload to do afterwards.
Originally Posted by 2K05GT
(Post 6355948)
All I have is this.. I need the Prefix and Suffix numbers for a full part number. http://i223.photobucket.com/albums/d...rparts2013.png I do have part numbers for the full mirrors too: D/S with PP and heat DR3Z-17682-DA P/S with PP and heat DR3Z-17682-AA
Originally Posted by ford20
(Post 6356209)
Harness as in quick connects? Because I was curious what it would take to run them in a base 2013 GT
2013 GT500 rear brake pads: BRF-1082-D ($66.63)
These will fit 2007-2012 GT500s and GTs and are more aggressive than the older pads. |
(Post 6356283)
The only part number I could come up with was DR3Z-13B374-A, and it looks like the price went up since you captured that. I tried a variety of other suffixes but couldn't come up with a second one. I don't believe it's the same part on both sides, but I could be wrong.
I do have part numbers for the full mirrors too: D/S with PP and heat DR3Z-17682-DA P/S with PP and heat DR3Z-17682-AA My understanding was in reference to a 2010-2012 car. You will most likely need some wiring harnesses in addition to the cluster as well, but I don't know for sure. If you need a harness, you're looking at thousands of dollars in most cases. |
(Post 6356615)
I guess there is only one way to find out :D
(Post 6356619)
Good luck. It's really not as easy as you think.
(Post 6356624)
Believe me, I expect to fail miserably ... But like you, I will do so like a boss :heh:
(Post 6356638)
Just do your homework. The downside to a swap as intensive as that is there are a lot of components, inputs, and other things to consider. I'd love to see someone do it, but I just don't think it's going to be possible.
