Nifty 2010 features
Old Sep 20, 2009 | 06:47 PM
Scott's Avatar
Nifty 2010 features
Just a couple of nifty things I have noticed with the 2010 that my 06 didn't do.
I do have the auto-headlights so it may just be those so equipped:
The My Color gauges stay white in the day time instead of going to the set color when you turn on the headlights. I had noticed with my 06 that with some of the darker colors it was hard to see the gauges if you ran headlights in the daytime, like when raining.
The auto headlights come on with the wipers, I had other cars in the past that the headlights did not come on with wipers.
I just thought that these features were cool and didn't know about them until after I bought the car.
Anyone find anything else that has not been discussed and some may not know about?
Old Sep 20, 2009 | 06:52 PM
unnoticedtrails's Avatar
cool!
Old Sep 23, 2009 | 02:18 PM
thomasstang09's Avatar
My parents just bought a 2010 premium V6 pony pack. The vanity mirror covers are in the mold of the hood. fyi
Old Sep 23, 2009 | 03:14 PM
jocatch's Avatar
Supposely the wiper speed changes with vehilce speed. Also, after 1/2 mile you will get a warning if the turn signal is still on. And I think if there is a problem with a system the corresponding gauge in the dash will turn red.
Joe
Old Sep 23, 2009 | 03:32 PM
theedge67's Avatar
The turn signal warning has been around since at least '05, same with the gauges turning red if there is a problem. Still cool features, but not new for 2010.
Old Sep 23, 2009 | 06:07 PM
kcsherman's Avatar
If you are running low on fuel and have Navigation The screen will show you Gas staion locations
Old Sep 23, 2009 | 08:46 PM
watchdevil's Avatar
We have a turn signal warning????? I never noticed it!
Old Sep 23, 2009 | 09:22 PM
stangfoeva's Avatar
MOTM Committee Member
doesn't the whole tach turn red when you reach the redline (man. trans only)?
Old Sep 23, 2009 | 09:24 PM
krnpimpsta's Avatar
Never noticed it either.. maybe I've just never forgotten?
Old Sep 23, 2009 | 09:33 PM
denlem's Avatar
I never knew that either. Guess what i'm gonna do tomorrow...
Old Sep 24, 2009 | 12:21 AM
theedge67's Avatar
No. At least not on the 05-09's. I have not heard anything different on the 2010's, but I suppose it is possible.
Old Sep 24, 2009 | 01:12 AM
Airsoft_fanatic's Avatar
The Tach does flash red when you redline.
Old Sep 24, 2009 | 05:35 AM
crescent_wrench's Avatar
Mine does....freaked me out the first time!
Old Sep 24, 2009 | 06:13 AM
Pro Mod's Avatar
wow, I wonder when they started that? My 06 GT did not do that. Believe me, I smacked the rev limiter plenty of times LOL
Old Sep 24, 2009 | 10:05 AM
2010MustangGT's Avatar
In the arm rest, the center portion (where your elbow and forearm can rest) the middle of it has a Gel underneath the leather for added comfort. Which is a night and day contrast over the 05-09 arm rest- in terms of comfort/material.
Old Sep 24, 2009 | 11:05 AM
denlem's Avatar
Just tried it on my '08. Drove over a mile with it on and there was no warning.
Old Sep 24, 2009 | 12:54 PM
WeinerDog's Avatar
Joe
I've never noticed the wiper speed change. It definitely doesn't slow down when you are stopped at a light or whatever.
I do like how the wipers make three passes, then wait 5 seconds and make an additional pass when you wash the windshield. I think all Fords do this now but it's a really cool feature.
Old Sep 24, 2009 | 06:07 PM
MyStang2010GB's Avatar
Here is another kewl thing I picked up from another Forum from a Ford engineer:
There is a way to display calibration data on your message center (display in your IP cluster)...
First, make sure the vehicle is off. Off-off: Key off and out of the cylinder, door opened and closed to reset accessory timers. Then, you have to hold the 'Setup' and 'Reset' buttons (above the headlight switch), then insert the key and turn the vehicle on (full ignition, not ACC), and release the buttons. The message center will display 'ENGINEERING MODE' and start with a gauge test. Pressing the 'Reset' button on the controls above the headlight switch will cycle you through a bunch of information on the CAN bus. Stuff like actual engine RPMs, actual coolant temp, fuel levels at each pump (there are 2 pumps since the fuel tank is saddle-shaped to accommodate the driveshaft), and a bunch of other stuff. To get out of engineering mode, turn the vehicle off. (Off-off, as defined above).
Old Sep 24, 2009 | 06:49 PM
theedge67's Avatar
I just tried it on my '06 and it does display some weird stuff, but nothing useful like RPM's or temps or anything. It's just useless software version info and stuff.
Old Sep 24, 2009 | 07:05 PM
For 2010 automatic GT, the gauge blinks red as well once you hit the redline but only when the driver is in the manual shift. It blinks through any or all of the 1st, 2nd or 3rd gear redlines. But when it's in D (drive) there are no blinks... Which makes sense.
